virtual ®   07-Dec-2018 17:50
Guide for Enhanced Shaft Alignment
Year: 2018
Author: ABS
Pages count: 28
Description: The intention of the Guide is to address shafting arrangements, such as installations with no forward stern tube bearing that may particularly benefit from a more detailed analysis and a more accurate and structured procedure so as to optimize the shaft alignment and improve the service life of the vessel’s powertrain. This Guide is intended to apply mainly to shaft alignment-sensitive vessels, although it could apply to a wider range of powertrains including geared installations.
esa-guide-dec18.pdf
Download [1 KB]
Guide for Enhanced Shaft Alignment - ABS [2022, PDF]
Guidance Notes on Propulsion Shafting Alignment - ABS [2019, PDF]
Guidelines on Main Propulsion Shafting Alignment - IACS [2025, PDF]
Guide for Enhanced Fire Protection Arrangements - ABS [2021, PDF]
Guide for Bridge Design and Navigational Equipment and Systems - ABS [2023, PDF]
Guide for Bridge Design and Navigational Equipment/Systems - ABS - ABS [2020, PDF]
Bearing Steel Technology - John.M.Beswick [2002, PDF]
Shell Rapid Lubricants Opica User Guide - Shell Marine [2014, PDF]
Reeds Engineering Knowledge - Instruments and Control Systems for Deck Officers - Embleton, William…
Water-Lubricated Journal Bearings | Marine Applications, Design, and Operational Problems and…
The time now is: Today 15:14
