virtual ®   01-Dec-2018 22:04
The Retransmission of SBAS Corrections Using MF‐Radiobeacon and AIS (G1129)
Year: 2017
Author: IALA
Genre: Technical book
Pages count: 40
Description: This document sets out guidance for marine Aids to Navigation (AtoN) service providers wishing to
understand where SBAS information could be used to support the mariner and then how to employ such
data.
While it is expected the mariners will use SBAS direct Signal in Space (SiS), the main purpose of the
document is to describe the SBAS use within augmentation services via marine radio beacon and AIS
transmissions. The document aims to consider common SBAS functionality, rather than focus on any
specific SBAS system, but does refer to specific SBAS services where required.
The document provides an overview of SBAS structure, use and general coverage areas. For the sake of
completeness, the direct use of SBAS from SiS on‐ board is introduced in section 3.1 and complementary
information is included in different annexes.
Recognising that the generation of differential corrections can be split from the means of transmission, a
number of different example architectures are provided in Section 4. These are meant as examples,
recognising that the infrastructure deployed and operational architecture will vary between service
providers.
Finally, operational aspects are addressed in section 6.
1129-Ed.1-The-retransmission-of-SBAS-corrections-using-MF-RB-and-AIS_Dec2017.pdf
IALA Guideline 1081 , Provision of Virtual Aids to Navigation, Edition 1.1 - IALA [2013, PDF]
IALA Guideline No. 1098 (On the Application of AIS - AtoN onBuoys) + IALA Guideline No. 1096 (Antici...
System of Differential Correction and Monitoring. SDCM, Interface Control Document, Radiosignals and...
MARCOM Manual (2024) - IALA [2024, PDF]
Navguide: Aids to Navigation Manual - IALA-AISM [2014, PDF]
VTS Manual - IALA [2024, PDF]
Boat Crew Qualification Handbooks - Vol 3, ATON (Aids TO Navigation) - US Coast Guard [2020, PDF]
the IALA Maritime Buoyage System - IALA [2023, PDF]
Navguide: Aids to Navigation Manual [2010, PDF]
Navguide: Marine Aids To Navigation Manual - IALA [2018, PDF]
The time now is: Today 21:41
