chayan_09 ®   20-Nov-2018 11:23
Marine Rudders and Control Surfaces - Principles, Data, Design and Applications
Year: 2007
Author: Anthony F Molland & Stephen R Turnock
Genre: Technical book
Publisher: Elsevier
Edition: 1st
ISBN: 978-0-75-066944-3
Pages count: 451
Description: Marine control surfaces are all pervasive and are used on a wide range of marine
vehicles as rudders, stabilisers and for pitch control. They can range in size from a
height of 40cm for a control surface on an autonomous underwater vehicle to a
height of 9 m and weighing over 80 tonnes for the redder on a large container ship.
An extensive amount of research and investigation into ship rudders and control
surfaces has been carried out over a number of years, including wide ranging
investigations by the authors into rudder-propeller interaction. The research has
generally entailed experimental and theoretical investigations and the main results
of many of these investigations have been published as contributions to Journals
and at Conferences. It is considered, however, that there is a need to bring together
the experimental and theoretical data sources and design methods into a book that
will be suitable both for academic reference and as a practical design guide.
Marine Rudders and Control Surfaces - Principles, Data, Design and Applications Anthony F Molland & Stephen R Turnock.pdf
Download [14 KB]
Marine Rudders and Control Surfaces - Anthony F. Molland, Stephen R. Turnock [2007, PDF]
The Maritime Engineering Reference Book A Guide to Ship Design, Construction and Operation by Anthon...
Advances in unmanned marine vehicles - Robert Sutton, George Roberts [2008, PDF]
Battery Reference Book - TR Crompton [2000, PDF]
Further Advances in Unmanned Marine Vehicles - G.N. Roberts, R. Sutton [2012, PDF]
Advanced Model Predictive Control for Autonomous Marine Vehicles - Yang Shi · Chao Shen · Henglai We...
Ship Resistance and Propulsion: Practical Estimation of Ship Propulsive Power - Anthony F.Molland, S...
Underwater Vehicles: Design and Applications - George M. Roman [2020, PDF]
Offshore Robotics: Volume I Issue 1 - Shun-Feng Su ,Ning Wang [2022, PDF]
Navigation and Control of Autonomous Marine Vehicles - Sanjay Sharma, Bidyadhar Subudhi [2019, PDF]
The time now is: Today 19:09
