Kerrang ®   14-Oct-2018 17:26
Draft Survey Professional
Year: 2018
Version: 3.0
Developer: Capt. Uygar's Apps
Platform: Android
64-bit OS compatibility: unknown
System Requirements: 2.2 and up
Crack: Not needed
Description: Draft survey, one of the most important elements of the maritime community which is used to calculate the amount of cargo loaded on board.
Additional info: Now you can do draft survey in all ships only with an app. Yes, it's right in all ships! If you are a draft surveyor in bulkcarrier ships or if you are the captain, forget about the excell programs made by officers and load masters.
The only thing you need is this app.You can save surveys which you made.
Draft Survey Professional v3.0.apk
Download [505 B]
Excel Draft Survey [2019,XLSX] Draft and Trim calculation - Capt.Leo [2019]
Draught Surveys a Guide To Good Practice, 2nd Edition - JIM DIBBLE, PETER MITCHELL and North of…
Draft Survey Practical Guidance - Britannia P&I Club [2023, PDF]
Ship’s Draught Survey calculation programs Collection - vary [200x]
Draft Survey Pro v.15.3 [2014] [Android]
Ship Stability-III Nutshell Series Book-6 - Capt. H. Subramaniam [2004, PDF]
Cargo Work & Maintenance - Capt. Errol Fernandes [1999, PDF]
On-off Hire Condition and Bunker Surveys - Captain A Brink [2020, PDF]
Stability Trim v.19.5.5 [2014] [Android]
Steel Pre-Load Surveys : Working through COVID-19 - The North of England P&I Association Limited…
The time now is: Today 13:21
