virtual ®   12-Oct-2018 22:02
Guidance Notes on Response Time Analysis for Programmable Electronic Alarm Systems
Year: 2018
Author: ABS
Pages count: 24
Description: The objectives of these Guidance Notes is to utilize block diagrams for programmable electronic alarms system architectural modeling, identify the critical elements of the design by means of a response time table and to suggest applicable equations for calculating the Worst Case Response Time. The aim of these Guidance Notes is to introduce both an optional common terminology and a generalized methodology for Response Time Analysis (RTA) efforts, targeting similar quality and consistency of engineering submittal to demonstrate meeting ABS Rules requirements for Response Time Analysis.
It is also the purpose of these Guidance Notes to further clarify the proposed methodology by means of example RTA calculations.
rta-gn-sept18.pdf
Download [772 B]
Safety And Environmental Critical Elements [2022, MP4]
Guidance Notes on Life Extension Methodology For Floating Production Installations - ABS [2021, PDF]
Guidance Notes on Propulsion Shafting Alignment - ABS [2019, PDF]
Review and Update of U.S. Coast Guard Vessel Stability Regulations and Guidance - Eugene A. van…
Safety Critical Equipment and Spare Parts Guidance - Oil Companies International Marine Forum…
Guidelines for Onboard CO2 Capture and Storage Systems - ClassNK [2025, PDF]
Guide for the the Assessment of Parametric Roll Resonance in the Design of Container Carriers -…
Maritime Cyber Risk Management Process: Case for American Liquefied Gas Carrier - JaHun Gu [202x,…
Shipboard Automatic Identification System Displays: Meeting the Needs of Mariners - Michel R.K.…
The time now is: Today 17:46
