virtual ®   12-Sep-2018 19:59
Resolutions of the International Hydrographic Organization, Publication M-3, 2nd Edition - 2010, Updated to August 2018
Year: 2018
Author: IHO
Genre: Convention (rules)
Pages count: 125
Description: The resolutions of the IHO are collated and published in IHO Miscellaneous Publication M-3. See resolution 13/1932 (Q3.1). M-3 is continuously updated as resolutions are added, amended or deleted.
In the first edition resolutions were allocated to chapters designated by a letter from A to T with chapters further divided into sections designated by a number. Individual resolutions were allocated numbers sequentially within a section e.g. resolution Q3.1. Following deletion the sequential resolution numbers were not reused. Over time many resolutions have been deleted following the transfer of information into other IHO Standards and Publications. Consequently by 2009 the first edition of M-3 had become somewhat disjointed with several sections empty and within those populated sections there were many gaps in the numbering sequence. Resolutions relating to specific subjects had, in some cases, also become spread across several chapters.
In this second edition those resolutions which remain extant have been allocated a number according to their first recorded entry in the bibliography of the 1st Edition of M-3. So for example resolution Q3.1 which is the thirteenth extant resolution with a first recorded entry of 1932 becomes resolution 13/1932. Where a resolution has been amended the words “as amended” are added after the resolution number. Where appropriate, for ease of reference, the old resolution number is included in brackets after the new number e.g. resolution 13/1932 (Q3.1). New resolutions adopted will be allocated sequential numbers within their year of adoption e.g. 4/2010 for the fourth resolution to be adopted in 2010. Two indexes have been included, one with the resolutions ordered according to the new numbering system and the second ordered according to the system used in the 1st edition.
The header bar for each resolution contains four elements:
a) The title of the resolution;
b) The reference number within this 2nd Edition;
c) The Circular Letter or IHC or Sessions of the IHO Assembly - reference of the latest amendment (if appropriate) and
d) The reference from the 1st Edition (if appropriate).
Tables providing references to the authority for the adoption, amendment and deletion of all resolutions are published in a separate Appendix to M-3.
M3-E-AUGUST18.pdf
Symbols, abbreviations and terms used on charts Eng-Esp - Instituto Hidrográfico de la Marina [2011,...
IMSBC Code and Supplement (2022 Edition, incorporating amendment 06-21) - IMO [2022, PDF]
IACS Green Book - International Association of Classification Societies (IACS) [2024, PDF]
IACS Green Book - IACS [2022, PDF]
Canadian Chart 1 Symbols, Abbreviations and Terms - Canadian Hydrographic Service [2022, PDF]
IACS Green Book - IACS [2020, PDF]
International Maritime Solid Bulk Cargoes Code (lMSBC Code) - IMO [2009, PDF]
IACS Green Book - IACS [2021, PDF]
Collection - Electronic Code of Federal Regulations (e-CFR) - regarding maritime sector - National A...
Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) - I...
The time now is: Today 04:39
