Val Ryman ®   29-Aug-2018 10:43
Model Boats Volume 68 Number 810
Year: 2018
Author: Graham Ashby (editor)
Publisher: MyTimeMedia Limited
Edition: May 2018
ISBN: 0140-2910
Pages count: 84
Description: Model Boats - May 2018
Racing sails - Dragon's Tale Part 2
Free plan - Freeman 22
Vintage corner - Model internal combustion engines
Design philosophy - Shallow but stable
Steam basics - part 89
Free plan - Alpha
Warship scale - HMS Iron Duke
Tall ships - Ship-rigged sail control
Readers' models - Tai Koo IV
Special feature - SS Mullogh Part 7
Plastic magic - Titanic Part 2
Warship scale - OSA 2 Fast missile boat
Fast electric
Subs & submersibles - NR-1 Part 4
Download [4 KB]
Arcan   12-Oct-2018 10:09
Val Ryman, Would you like to fix it? I changed status of your release to "not formalized until" that you can edit and add proper picture.
Val Ryman ®   13-Oct-2018 04:36
Arcan, Hi! Yes, I would like to fix the cover. I of course have the correct image and have uploaded it to seatracker (but may need to do it again).
To explain: I am dependent on the PC that I can access in different ports. The PC I use in Malaysia had a browser that crashed when uploading graphics. And I discovered just this voyage that it had a filter banning a wide range of IP addresses that included several of the seatracker-associated IP addresses. I think I have removed that filter. And I've upgraded the browser. But I of course do not have full control of that PC.
How can I change the cover picture?
Val Ryman ®   13-Oct-2018 04:44
Arcan: Hi!
I think I have now successfully updated the page with the correct image!
VR
Model Boats Volume 68 Number 809 - Graham Ashby (editor) [2018, PDF]
Model Boats Volume 68 Number 811 - Graham Ashby (editor) [2018, PDF]
Model Boats Volume 68 Number 812 - Graham Ashby (editor) [2018, PDF]
Model Boats Volume 68 Number 807 - Graham Ashby, editor [2018, PDF]
Model Boats Volume 68 Number 808 - Graham Ashby, editor [2018, PDF]
Model Boats Volume 68 Number 814 - Martyn Chorlton, editor [2018, PDF]
Model Boats - January 2018 - Graham Ashby, editor [2018, PDF]
Model Boats Volume 68 Number 815 - Martin Chorlton, editor [2018, PDF]
Model Boats Volume 68 Number 816 - Martyn Chorlton, editor [2018, PDF]
Model Boats Volume 68 Number 813 - Martyn Chorlton, editor [2018, PDF]
The time now is: Today 03:54
