sumityad1509 ®   09-Aug-2018 07:05
Cooling Water Treatment Principles and Practice - Colin Frayne (Chemical Publishing, 1999)
Year: 1999
Author: Colin Frayne
Genre: Technical book
Publisher: Chemical Publishing Co. Inc. , New York
Pages count: 571
Description: Cooling Water Treatment Principles and Practices: Charts and Notes For Field Use; Is the companion field guide handbook to Cooling Water Treatment Principles and Practices by Colin Frayne. In this handbook you will find many helpful formulas for use in the field such as formulas for: Refrigeration in cooling towers, Conductive heat flow, General industrial and cooling water makeup contents, Coagulants and flocculants, Filter types, Water softeners, Commonly found corrosion types, Mineral and silica deposit types, Equations for solving pH, Common bacteria and Fungi types, Inhibitor components, A suggested biocide selection chart for comfort cooling systems, A cleaning and disinfection program for cooling systems, and Cooling water control parameters. The charts and formulas contained in this field handbook provide an overview of many situations encountered in the field and will aid in the diagnosis and solution of many water issues you will encounter on the job. Also provided are two separate sections for keeping notes on specific issues.
Total Dissolved Solids (TDS) , total hardness , cooling water inhibitors
Cooling Water Treatment Principles and Practice - Colin Frayne (Chemical Publishing, 1999).pdf
Download [29 KB]
Arcan   09-Aug-2018 07:58
sumityad1509, And here also: what about content of this book?
How to edit your release - read here
Seeder not seen: Never
I suppose, you forget to download back your torrent file and add it to your client. Therefore nobody can download it
sumityad1509 ®   09-Aug-2018 08:26
i have added the torrent and in the same location but i am doing all this from my phone i should be doing it from my laptop right .
Arcan   09-Aug-2018 09:08
sumityad1509, You have not only put in the same location torrent file, you need to add it to your client software the same way as you usually add any torrents for downloading.
For example, utorrent wil ask you:
You have to push "Yes" button
Arcan   09-Aug-2018 13:06
sumityad1509, Registered: 3 days | Completed: 0 times
Arcan   12-Aug-2018 10:17
sumityad1509, will await 1 day more for seeder, then, if not appeared, release will be deleted.
HVAC - Equations, Data, and Rules of Thumb, 2nd Edition - Arthur A. Bell JR., P.E. [2007, PDF]
Marine Online - Ballast Water Management Methods [2016, MP4]
Refrigeration and Air Conditioning - W.F. Stoecker, J.W. Jones [1983, PDF]
Class One Engineering Knowledge, South Tyneside College [2007, PDF]
Mothballing Program & Calculations for oil & gas pipelines [2024, MP4]
Introduction to Fluid Mechanics - Edward J. Shaughnessy, Jr. [2005, PDF]
Boiler Operation Engineering: Questions and Answers - P. Chattopadhyay [2008, PDF]
Refrigeration and Air-Conditioning - A. R. Trott and T. Welch [2000, PDF]
NALFLEET Marine Chemicals - Interactive Management System [1998, PDF]
REEDS Vol 8: General Engineering Knowledge for Marine Engineers - Paul A Russell [2024, PDF]
The time now is: Today 02:56
