Edwin ®   05-Mar-2018 14:50
Gyro Mate Pro
Year: 2017
Version: 1.13
Developer: vlad.zdx
Platform: Android
64-bit OS compatibility: unknown
Localization: multilingual
Crack: Not needed
Description: The application calculates the Sun, Planets and Stars azimuth based on observer's location and time of observation.
No additional publications required: nautical almanac, etc.
Once the azimuth is calculated, entering gyro bearing, heading, magnetic heading, variation will
produce the result summary with all data required to keep the Compass Observation Book in right way.
"Star Adviser", this new option will help you to locate the objects and select the best one for bearing;
This will also allow to predict the planets and stars location, so you can plan your measurements.
The "Star Adviser" will indicate the available planets by text color as well.
Available planets means: the one is bright enough to see by naked eye (magnitude < 6) and it is above horizon.
Moon phase added.
Download [8 KB]
Arcan   05-Mar-2018 17:52
Edwin, Kindly next time follow this recommendations:
1. Release name should be the same as original. ( fixed)
2. Screenshots should be proper size that user can see the same as on screen of cell phone. (fixed)
3. Screenshots should be at least 3 as per rules. (fixed)
Edwin ®   04-Nov-2018 17:55
I have discovered grave errors in this application, although I posted it, I do not advise it for use on board
Gyro Mate v.1.17 - vlad.zdx [2017] [Android]
Nautical Almanac v.2.3 - Maksym Skrypkin [2024] [Android]
AstroNav v.1.1.7 - Navsoft [20??]
Nautical Almanac’s Nautical Starfinder - UNKNOWN [2017]
Burdwood’s Tables Second Edition (DAVIS. 2) - Sun’s True Bearing or Azimuth Tables - Percy L. H.…
Nautical Calculator Pro v.9.2.0 - Giacomo Gabriele [2022] [Android]
The time now is: Today 16:07
