SerTan ®   27-Jan-2018 22:10
Brown's Nautical Almanac
Year: 2018
Author: Brown, Son & Ferguson, Ltd
Publisher: Brown, Son & Ferguson, Ltd
Edition: 141st
ISBN: 9 781849 270763
Pages count: 636 (originally 1251)
Description: First Published 1876; Revised and Updated for 2018. Well known in every port throughout the world.
Published annually in October for the following year.
Brown's Nautical Almanac 2018 contains a full nautical almanac for sun, moon, stars and planets for 2018. Also included:
- True Rhumbline Distance (WGS-84 Calculations (13 pages),
- Trans-oceanic Passages by Rhumbline Sailing - Method A1NA2,
- Difference in Nautical Miles between True Rhumbline Distance (WGS-84) and GPS Rhumbline Distance,
- Distance Correction for Converting Theoretical (Sphere) into Correct Practical Great Circle Distances,
- Correct (accurate) Mercator Chart (WGS-84) Construction, Trim Calculations.
- Metacentric Height and List Calculations, with List Draft Changes, etc.
- Draft Surveying and Displacement Calculations (5 pages),
- How to get Trim and Drafts Forward and Aft by Distance between Longitudinal Centres of Buoyancy and Gravity,
- Tank's Vertical Centre of Gravity, Free Surface in the Tank,
- Useful Information for Safety of Navigation and a Ship, Sailings, Great Circle Sailing,
- Differences in Nautical Miles between Great Circle Distance (Sphere) and Theoretical Geodesic Curve Distance (Spheroid, WGS-84), etc.
See Screenshots.
Brown's Nautical Almanac 2018.pdf
SerTan ®   27-Jan-2018 23:33
так это не сильно напряжно - 2 стр на один скан))) Там где каждая страница на один скан - напряжнее! У меня 2 кадета - Зарабатывают промоушен))) Матрос
10
Fletum   02-Feb-2018 21:14
lapadu, Подскажите как можно скачать эту книгу ?
Arcan   28-Feb-2018 11:35
qchiang, Yes of course! You can! Just earn reputation at least = 1 and go ahead!
3
Arcan   06-Mar-2018 11:44
KIMO29, I already replied to this question two posts above. Read carefully and follow instructions.
c3cil1k   19-Mar-2018 15:19
Great book! This is a must have onboard! it contains important informations regarding publications, formulas, tables for conversions and others. it's good even if the almanac is expired . Писатель!
slavaice   04-Apr-2018 23:56
Кто знает есть ли эта книга на русском языке? И где ее найти?
ERMO83   08-May-2018 22:13
РАСПОЗНАЛ КАК ТЕКСТ. ТЕПЕРЬ РАБОТАЕТ ПОИСК ПО СЛОВАМ. КУДА ВЫЛОЖИТЬ?
SerTan ®   08-May-2018 23:59
ERMO83, А ошибки после распознания присутствуют в большом кол-ве ? проверьте, особенно в местах с формулами.
Brown’s Nautical Almanac - Brown, Son & Ferguson Ltd [2020, PDF]
Brown’s Nautical Almanac [2016, PDF]
Brown’s Nautical Almanac [2017, PDF]
The Principles and Practice of Navigation - A. Frost [1997, PDF]
Brown’s Nautical Almanac 2026 Edition - Brown, Son & Ferguson Ltd [2025, PDF]
Practical Advanced Navigation - Charles H. Cugle [1922, PDF]
The time now is: Today 20:33
