Arcan ®   23-Jan-2018 20:34
Marine Online - Engine works
Year: 2017
Playtime: 62:12
Quality: WEB-DL
Format: MP4
Video: 640x360 / 161 kbps / 16:9
Audio: 96 kbps / 44.1 KHz
Description: This 12 video lessons consist of following items:
More info
1.Engine Type Designation
The objective of this video section is to make operational personnel acquainted with:
• Engine Type designation
• Technical Data
2.Engine Safety
The main purpose of this video section is to given all operating personnel a basic understanding
of the importance of taking necessary safety precautions, and to be aware of potential hazards
when operating the auxiliary engines.
3.Start and Stop Routines of Diesel Engines
The main purpose of this video section is to make the operators able to:
• Describe components and system which should be operating during start-up.
• Describe components and systems which should be in standby mode during start-up.
• Recognize the components to operate during start-up.
• Describe what actually happens with in the system during start-up.
• Describe the critical parameters and know where to find the measuring instruments.
• Rectifying actions in case of deviation.
4.Engine Safety System
The main purpose of this section is to give all operationg personel a basic understanding of :
• The engine most essential functions.
• How the Engine Safety System Work.
5.Engine Governing System
• How the Engine Governing System Work.
6.Engine Fuel Oil System
The main purpose of this section is to give all operation personnel a basic understanding of :
• How the Engine Fuel Oil System Work.
7.Jacket Cooling Water System
• How the Jacket Cooling Water System Work.
8.Rocker Arm Lubricating System
• How the Rocker Arm Lubricating System Work.
9.Main Lubricating Oil System
• How the Main Lube Oil System Work.
10.Control Air System
• How the Control Air System Work.
11.Engine Air Starting System
• How the Engine Air Starting System Work.
12.Exhaust System
• How Exhaust System Work.
Auxiliary Engines [2017, MP4]
Marine Online - Safe Working Practices [2018, MP4]
LPG/C YUKON - Cargo Plant Instruction Manual - Babcock LGE [2019, PDF]
Safety, Operating & Maintenance Instructions Marine Auxiliary Boiler – Miura GK Series - Miura Prote...
MAN B&W L28/32H Manual - MAN B&W Diesel A/S [2005, HTML]
MAN B&W L27/38 | Instruction manual | Volume I+II [1994, PDF]
Operator’s Manual for Engine Room Simulator ERS L11 5L90MC VLCC (Version MC90-V) - Kongsberg [2009, ...
Auxiliary Boiler H_Type Z_Boiler Instruction Manual - Miura CO.LTD [2006, PDF]
Whiting crane handbook - H. G. Greiner [1955, PDF]
A Master’s Guide to Using Fuel Oil Onboard Ships - Mark C. Ford [2012, PDF]
The time now is: Today 08:46
