iqbal ®   08-Jan-2018 18:02
INTERTANKO Guide to Safe Navigation (Including ECDIS)
Year: 2017
Author: Intertanko
Pages count: 36
Description: Intertanko Publication: Guide to Safe Navigation (Including ECDIS), First Published in 2017.
During the INTERTANKO Safety and Technical Committee (ISTEC) meeting in London (9-10 March 2016) it was decided that the “Navigation, Safety, Ports and terminals working group” should become a Sub-Committee of ISTEC. Formal approval of this change was taken by the INTERTANKO Council in May 2016. One of the main issues for the NSC has been to create Guidelines for their Members when it comes to safe use of ECDIS during navigation, such as this document.
The only way to ECDIS performance excellence is through continuous training and establishment of an open forum where issues encountered with ECDIS operations are brought forward.
Introduction.
Zone of Confidence (ZOC).
Under Keel Clearance (UKC).
Area Settings.
Frequency of Position Fixing in Paper Charts and Frequency of Position Verification in ECDIS/Chart radars.
Depth Contours In ENCs in Relation to Safety Contour and Safety Depth Function.
Temporary And Preliminary Notices.
Air Draft.
Use Of ECDIS On Ships Having Paper Charts As Primary Means Of Navigation.
Annex I.
Annex II.
INTERTANKO Guide to Safe Navigation 2017.pdf
Download [17 KB]
iqbal ®   08-Jan-2018 18:58
Arcan, Do not know how to add more screenshots after it was uploaded. Will remember next time.
Arcan   08-Jan-2018 19:04
Read carefully here and follow instruction - it's very easy.
Otherwise your release is not finalized.
SerTan   08-Jan-2018 20:11
iqbal,
Everything was ajasted as it should be.
Thanks for starting to be a seeder!
But next time plese make a bit more wide explanation of the book (it can be found at internet or at Preface of book itself).
And pls try to follow the requrements written at RULES section.
Может по пиву?
Guide to Safe Navigation (including ECDIS) 17 th Edition - INTERTANKO [2017, PDF]
Guide to Safe Navigation (Including ECDIS) - INTERTANKO [2021, PDF]
Guidelines on how to deal with seafarer abandonment cases - ILO & IMO [2022, PDF]
INTERTANKO Guidance: Dry-Dock Checklist 2019 - Intertanko [2019, PDF]
Intertanko - Guidance Booklet on Seafarers´ hours of work and rest - INTERTANKO [2008, PDF]
Guidance Document on the Implementation of an Incident Management System (IMS) - IMO [2012, PDF]
Anchoring Guidelines: A Risk-Based Approach - INTERTANKO [2019, PDF]
Model Ship Builder - Collective [2007, PDF]
Guidance on Chartering Issues Relating to Covid-19 - Intertanko [2020, PDF]
Guidelines for the Alleviation of Excessive Surge Pressures on ESD - SIGTTO [1987, PDF]
The time now is: Today 19:03
