CaptainWhite ®   16-Oct-2017 23:23
Cranes, their operations and reasons for failures
Year: 2015
Author: JAPAN P&I CLUB
Publisher: JAPAN P&I CLUB
Edition: Vol.36, October 2015
Pages count: 20
Description: Cargo handling cranes, commonly pedestal mounted jib cranes, are fitted on board most handy-size bulk carriers, most general cargo ships and some other smaller or larger bulk carriers. These cranes appear to be fairly robust units which will continue to work when only a minimum of maintenance is carried out, but, in fact, they are highly complex pieces of machinery which incorporate numerous components manufactured to very fine tolerances, all of which must function correctly throughout a working period for the crane, as a unit, to be operated as the manufacturers intended. The cranes should be properly maintained, and should be inspected at specified intervals to ensure that they operate correctly and safely. Additionally, all other equipment used in association with a crane should, likewise, be properly maintained and should be inspected as appropriate. If the equipment is not in the appropriate good condition, failures are likely to occur during cargo operations.
Cranes
Crane Slewing Gear Maintenance and Rocking Tests - The West of England P&I Club [2023, PDF]
Lifting Plant (Cargo Handling) - the North [2019, PDF]
Port Information Guide Rotterdam - Rotterdam Port Authority [2021, PDF]
Deck Stowage and Securing of Pipes - Charles Bliault, Hermann Kaps [2008, PDF]
Requirements of Liquefied Carbon Dioxide Carriers - ABS [2024, PDF]
Carriage of Energy Storage Units on Bulk carriers - Britannia P&I Club [2023, PDF]
Preventing of Cargo Shortage - Takehiro Endo [2016, PDF]
Master’s Guide for Hatchcovers Maintanance [PDF]
Cargo Handling Book - MacGregor [2016, PDF]
Efficient cargo handling solutions for bulk carriers, container ships and general cargo vessels - Ma...
The time now is: Today 03:01
