SerTan ®   20-Sep-2017 23:48
Use of Workboats for Towage - Good Practice Guide
Year: 2016
Author: National Workboat Association
Publisher: NWA
Edition: 1
Pages count: 21
Description: These towage guidelines have been developed by the National Workboat Association in the light of recent towage incidents. They are primarily aimed at the main workboat towage areas, towing non-propelled barges and other objects in port, on coastal work sites and for coastal towage voyages, and bearing in mind that most workboats are of conventional propulsion, albeit mainly twin screw and quite manoeuvrable. Although many of the basic principles apply to both forms of towage, those engaged in ‘ship assist’ port towage should
also refer to the more specialised guidance available, as in the references in the back of this guide.
Additional guidance on the safe use of gogs to prevent girting has been added to the Guide as there is a lack of clear guidance available on this topic, and it is a significant risk for workboats in particular as can be seen from the girting incidents recorded by the UK Marine Accident Investigation Branch (MAIB).
NWA_Towage_Good_Practice_Guide_Final_MM.MR_23.12.16.pdf
Download [766 B]
Recommended Practices for Diving Operations - International Association of Oil & Gas Producers…
HSE Brief Safety Guides - HSE [2005, PDF]
Safety Digest, Lessons from Marine Accident 2015 - 2019 - Marine Accident Investigation Branch…
Safety Digest, Lessons from Marine Accident Reports No 2-2020 - Marine Accident Investigation…
Safety Digest, Lessons from Marine Accident Reports No 1-2020 - Marine Accident Investigation…
Safety Digest | Lessons from Marine Accident Reports - Marine Accident Investigation Branch (MAIB)…
MAIB Safety Digest 1/2022 - MAIB [2022, PDF]
Bridge Watchkeeping Safety Study - MAIB ( Marine Accident Investigation Branch ) - Marine Accident…
Safety Flash issue 01 (January) - IMCA [2024, PDF]
MAIB Safety Digest 2/2022 - MAIB [2022, PDF]
The time now is: Today 15:20
