BlackMongooses ®   12-Feb-2017 20:12
Inside Oil Tankers - Documentary Films
Genre: Документальный
Duration: 00:47
Description: All over the world, tanker operations are constantly moving. Oil tankers are ships specially designed for the bulk transport of either unrefined crude oil or petrochemicals. Their size classes can range from coastal or inland tankers of a few thousand metric tons of deadweight (DWT) to a colossal amount of 550,000 DWT. These giant specialized ships transport approximately two billion metric tons of oil across the sea every year.
Crude oil is one of the world's most consumed sources of energy. Oil tankers, therefore, play a significant role in the way the country operates. Because of the products they are built to carry, without proper maintenance, these mammoth ships of black gold can also pose a threat on the environment.
To ensure that an oil tanker does not severely impact the environment, oil companies must employ an expert and highly experienced ship management service to oversee tanker operations. They must also routinely check their oil tankers for maintenance purposes. Fixing the smallest dent, scratch or crack can mean the difference between safe sailing across miles of seawater and a devastating oil spill.
On board the ship, safety measures should be strictly imposed. Because of the hazardous - and often flammable - nature of the materials being transported, the possession of flammable objects should be avoided if not prohibited entirely to avoid accidents, which can threaten the lives of the people on the ship, as well as the surrounding marine life.
Whether at sea or anchored at a dock, tanker operations and safety measures should still be strictly implemented to prevent the ship from negatively affecting the environment.
Внутри нефтяных танкерах - документальные фильмы
Во всем мире, танкерные операции постоянно перемещаются. Нефтяные танкеры, корабли, специально предназначенные для перевозки наливом любого нерафинированного сырой нефти или продуктов нефтехимии. Их классы размер может варьироваться от прибрежных или внутренних танкеров несколько тысяч тонн дедвейта (DWT) к колоссальному количеству 550,000 DWT. Эти гигантские специализированные суда транспортировать около двух миллиардов тонн нефти через море каждый год.
Сырая нефть является одним из наиболее потребляемых в мире источников энергии. Нефтяные танкеры, следовательно, играют важную роль в том, как страна работает. Из-за продуктов, которые они построены, чтобы носить с собой, без надлежащего технического обслуживания, эти гигантские корабли черного золота также может представлять угрозу для окружающей среды.
Для того, чтобы гарантировать, что нефтяной танкер не сильно влияет на окружающую среду, нефтяные компании должны использовать эксперта и многоопытного службы управления корабля для наблюдения за операциями танкеров. Они также должны регулярно проверять свои нефтяные танкеры для целей технического обслуживания. Крепление наименьший вмятина, царапина или трещина может означать разницу между безопасной плавания через миль морской воды и разрушительного разлива нефти.
На борту судна, меры безопасности должны быть строго наложены. Из-за опасной - и часто огнеопасно - природа материалов, перевозимых, обладание легковоспламеняющихся предметов следует избегать, если не запрещено полностью, чтобы избежать несчастных случаев, которые могут угрожать жизни людей на корабле, а также окружающей морской жизнь.
Будь то на море или на якоре в док, танкеров операции и меры безопасности должны по-прежнему строго соблюдать, чтобы предотвратить судно от негативного воздействия на окружающую среду.
Танкера
Download [20 KB]
Безопасность на танкерах-химовозах / Safety in chemical tankers - ЦНИИМФ [2001, PDF]
Chemical Tanker Tank-Cleaning - Navios Tanque [2011, PDF]
DNV Guide to Port State Control [2000, PDF]
Thomas’ Stowage - Thomas, R.E. [2002, PDF]
Безопасность на танкерах - Баскаков С.П. [2003, DOC]
Port State Control 2020 Annual Report - BlackSea MOU [2021, PDF]
Guidance on Inspections of Ships by the Port States in Accordance with Regulation (EU) 12572013 on…
Энциклопедия выживания на море - Потапов А. [2017, PDF/DOCX]
Спасательные плоты - Общие сведения / Установка / Выживание - Неизвестно [2010, PDF]
Cargo Advice - Hazardous Chemicals - The Swedish Club [2022, PDF]
The time now is: Today 15:08
