iivanov191982 ®   24-Nov-2016 08:21
CATBOAT GUIDE and SAILING MANUAL
Author: Edward Steinfeld
Description: These boats can be slower than other less beamy boats on certain points of sail.
Can’t be raced against sloops fairly, without some attention to the handicap ratings.
The vessel will be very hard to right if capsized (although capsizing is somewhat more difficult to achieve).
Less sail redundancy. Most catboats only have one mainsail and generally no extras. Whereas, sloops, ketches,
schooners, yawls, etc., carry at least a main and a headsail or two, providing redundancy should one sail fail.
In smaller catboats, the cockpit is so large that getting pooped could be disastrous.
Due to the one single large sail, the skipper must understand the need to reef earlier before the winds and the sail
become unmanageable. Many skippers don’t care to reef and this can turn into a dangerous situation.
Catboats are frequently known to have heavy weather helm.
Most catboats have low freeboard with a curvaceous sheer line.
CATBOAT THESIS...................................................................................................................1
A BRIEF HISTORY OF CATBOATS.....................................................................................3
MOORING AND DOCKING...................................................................................................4
Docking ....................................................................................................................................................................................... 4
Docking and Mooring ............................................................................................................................................................. 5
Docking Lessons ...................................................................................................................................................................... 6
DOCKING OUTBOARD-POWERED SMALL SAILBOATS..............................................9
Approaching the Dock ........................................................................................................................................................... 9
Angling the Boat Properly and Coming to a Stop........................................................................................................ 9
Turn the Rudder, Turn the Engine .................................................................................................................................. 10
MENGER CAT 19 OWNER'S MANUAL.............................................................................11
Stepping and Lowering the Tabernacle Mast ............................................................................................................. 11
Trailer Procedure................................................................................................................................................................... 12
Sailing Tips .............................................................................................................................................................................. 13
First Reef ............................................................................................................................................................................. 14
Second Reef ........................................................................................................................................................................ 15
TRIMMING THE SAIL..........................................................................................................16
How to get rid of Weather Helm?.................................................................................................................................... 16
Quick study guide.................................................................................................................................................................. 16
What I do to trim the sail is... .......................................................................................................................................... 17
Sail Trim.................................................................................................................................................................................... 17
Short Peak Halyard Primer ................................................................................................................................................ 18
Catboat Sail Trim................................................................................................................................................................... 19
How ‘deep throat’ can give better performance in a single-sail, gaff-rigged boat................................................ 19
Angle of attack ................................................................................................................................................................... 19
Draft ..................................................................................................................................................................................... 19
Twist..................................................................................................................................................................................... 20
Trimming to conditions ..................................................................................................................................................... 20
Points of sail........................................................................................................................................................................ 20
ANCHORING ..........................................................................................................................22
HEAVING-TO IN A CATBOAT ...........................................................................................24
Family Cat ................................................................................................................................................................................ 24
Marshall Sanderling.............................................................................................................................................................. 24
Horizon Cat .............................................................................................................................................................................. 24
Sun Cat ...................................................................................................................................................................................... 25
RIGGING AND LAZY JACKS..............................................................................................26
Rigging Length of Line Chart - Sanderling .................................................................................................................. 26
Single Line Reefing............................................................................................................................................................... 29v
Description of Lazyjacks on Cat Nap.............................................................................................................................. 29
Another Sun Cat Lazy Jacks Installation...................................................................................................................... 31
Still Another ............................................................................................................................................................................ 32
Homemade Lazy Jacks ........................................................................................................................................................ 33
Lazy Jacks (Picnic Cat) ....................................................................................................................................................... 35
Simple Lazy Jacks for a Sun Cat ...................................................................................................................................... 36
MODIFYING SUN CAT'S RIGGING .................................................................................37
Adding Lazy Jacks................................................................................................................................................................. 40
Creating a Gaff Boom Downhaul ..................................................................................................................................... 40
Improving the Reefing System ........................................................................................................................................ 40
Making an Adjustable Outhaul ......................................................................................................................................... 41
John’s Changes ...................................................................................................................................................................... 41
MORE SUN CAT MODS ........................................................................................................42
SUN CAT UNDER BRIDGEDECK CABIN STORAGE.....................................................49
NEW SAIL FOR THE SUN CAT ..........................................................................................53
SUN CAT WATER LEAK FIXES..........................................................................................54
MAST AND SAIL RAISING TIPS......................................................................................56
Raising the Sail (Com-Pac)................................................................................................................................................ 56
Raising the Mast (Sun Cat)................................................................................................................................................ 56
Raising the Sail (Sun Cat).................................................................................................................................................. 57
Holding Course while Raising the Sail........................................................................................................................... 59
Trimming the motor .......................................................................................................................................................... 60
Menger Tips ............................................................................................................................................................................. 60
To lower the sail: ............................................................................................................................................................... 60
As to reefing:...................................................................................................................................................................... 60
STEP STORAGE SYSTEM FOR SUNCATS.......................................................................61
PICNIC CAT UPGRADES.....................................................................................................65
More Picnic Cat Mods ........................................................................................................................................................... 70
Installing Swim Ladder and Motor Bracket................................................................................................................. 71
Cockpit Hatch Hasps ............................................................................................................................................................ 74
Flotation Bags and Pointed Screws................................................................................................................................ 75
PICNIC CAT SPAR SPECS..................................................................................................76
DM-284 Mast ........................................................................................................................................................................... 76
DM-275 Boom ......................................................................................................................................................................... 77
DM-1 Gaff ................................................................................................................................................................................. 77
PICNIC CAT SAIL DIMENSIONS.....................................................................................78
PICNIC CAT RUDDER NOT PLUMB.................................................................................79vi
REEFING – HOW AND WHY..............................................................................................81
A DIALOG ON REEFING .....................................................................................................83
JIFFY REEFING INSTALLATION – SUNCAT ................................................................84
REPLACING SEATS ON A SANDERLING .......................................................................86
KEEP THE BOOM FROM SWINGING ..............................................................................88
CAPSIZING.............................................................................................................................94
TRAILERING ADVICE..........................................................................................................97
QUESTIONS ABOUT TRAILERING..................................................................................98
Tongue Weight, Tilting, Wheel Size, Bearing Buddies ........................................................................................... 98
AUTOPILOT/TILLERPILOT .............................................................................................101
ST1000 installed.................................................................................................................................................................. 101
Raymarine ST1000 & ST2000 Tillerpilots .................................................................................................................. 102
DEPTH GAUGE INSTALLATION .....................................................................................104
SUN CAT MAIN SHEET/TRAVELER RELOCATION...................................................105
SWIM LADDER STEPS ......................................................................................................107
IDASAILOR RUDDER FOR THE PICNIC CAT.............................................................109
SCUPPERS ............................................................................................................................111
Water Coming In Through the Scuppers.................................................................................................................... 111
Drain Tubes and Scuppers ............................................................................................................................................... 111
ANCHORS..............................................................................................................................113
SUN CAT STABILITY .........................................................................................................114
OUTBOARD VS. INBOARD...............................................................................................116
MUST HAVES FOR A CAT BOAT .....................................................................................117
Comments from others ..................................................................................................................................................... 117
Teak Cockpit Grates ........................................................................................................................................................ 117
Tiller Tamer....................................................................................................................................................................... 118
MARSHALL VS MENGER VS COM-PAC.........................................................................119
PICNIC CAT REVIEW ........................................................................................................120
HA-18 VERSUS SANDERLING........................................................................................122
LENGTHS AND SURFACE AREA .....................................................................................123
MELONSEED CONVERSION.............................................................................................125
POINTS OF SAIL.................................................................................................................134
FLAG ETIQUETTE................................................................................................................136vii
The Flags ................................................................................................................................................................................ 136
Ensign................................................................................................................................................................................. 136
Burgee................................................................................................................................................................................ 136
Private Signal.................................................................................................................................................................... 137
Courtesy Flags.................................................................................................................................................................. 137
Flags' Dimensions ............................................................................................................................................................... 137
Raising and Lowering Flags ............................................................................................................................................ 137
RENAMING A BOAT ...........................................................................................................139
Afterwards ............................................................................................................................................................................. 139
Vigor's Denaming Ceremony........................................................................................................................................... 140
Christening Ceremony ....................................................................................................................................................... 140
GLOSSARY ............................................................................................................................141
catboat_Guide_and_Sailingmanual.pdf
Download [8 KB]
Basic Cruising: The National Standard for Quality Sailing Instruction - U S Sailing Association…
Captain John’s Top Sailing Tips- Captain John Jamieson [2013, PDF]
Fast track to sailing - Steve and Doris Colgate [2009, PDF]
Stress-free Sailing - Duncan Wells [2015, MOBI]
Best Sailing Tips 2012 - Captain John Jamieson [2012, PDF]
Rigging Handbook - A Comprehensive Guide to Sailboat Rigging - Benavent H. [2026, PDF/ePUB]
Tall Ships - The Magic of Sail - Server D. [1999, PDF]
Yachting - Start to Finish - BARRY PICKTHALL [2015, PDF]
PRACTICAL JUNK RIG Design, Aerodynamics and Handling - HG Hasler, JK McLeod [1988, PDF]
The handbook of sailing [1992, PDF]
The time now is: Today 17:12
