gavra   26-Feb-2025 08:20
I do everything as it is written in the institutions, but every time I turn on the Internet and it asks me for a UM code
PLEASE HELP
matrixdu   26-Feb-2025 11:33
gavra,
1.Turn off internet connection
2.start the installer "InstallProfessional v4.2.0.132 (build 4.2.186.0) Professional" ,when installtion completed uncheck the "Do you want to Run TimeZero" and close the popup window.
3.Run "MX_TZ v4PRO_crack_SplahScreen" and press continue. it will automatically close.
4.Run "Block Host.cmd" to avoid the UM code issue every time you execute TIMEZERO.
5.Run the keygen "MaxLicV4Pro_R5" and TZ4 application .
generate your serial number and put it on tz , press next you will see the SC code on the second window
copy paste in the keygen and generate the AC code.
Congratulation installation completed.
3
justin091631   26-Feb-2025 14:36
"Does anyone know how to modify the weather service IP address in TimeZero Professional V4.2.0.132, or how to directly download the built-in weather forecasts within the software?"
justin091631   26-Feb-2025 18:17
"Does anyone have the official installation file links for **TimeZero Professional V5 (TZ V5)**?"
gavra   27-Feb-2025 09:25
I have a problem... when I install v.4.2.0.132 it doesn't find my GPS but on version 1.98 there is no problem. What do you think could be the problem?
PLEASE HELP
gavra   27-Feb-2025 10:42
matrixdu,
The cable I use to make the connection is a COMPORT from GPS to USB for a laptop.
matrixdu   27-Feb-2025 11:07
gavra, thats ok,but check on which com port you are receiving gps signal to TZ (connection wizard in TZ)
gavra   27-Feb-2025 13:45
matrixdu, I solved the problem and if anyone else has the same problem, they should know that they need to upgrade the CH34 driver.
matrixdu   01-Mar-2025 10:23
R9E9D,simple...use map manager
Attachments MapManagerSetupV2.7.1.zip (70 MB, Downloaded: 86 times)
3
Leobardo   01-Mar-2025 22:57
R9E9D, Baja el Mapmanager de la liga que esta puesta y ahi encontraras lo que buscas
Gunslinger   04-Mar-2025 04:26
Did anyone find a way to download weather data, sea surface temperatures and water currents ?
The time now is: Today 17:43
