Pipe   06-Jan-2025 22:38
Hola ,tengo un amigo que tiene unas cartas y unos achivos 3d y quisiera pasarlas mi ordenador se puede hacer?o hay algún sitio para descargarlas?Las cartas son las siguientes:
SDVJEWM228MAP22. DBV
ESP10HSAT01.DBA
SD31P01TIN02.DBT
SDEWM009TIN02.DBT
SDEWM228TIN01.DBT
SDEW228FISHMAP01.DBB
Hello, I have a friend who has some charts and some 3d files and I would like to pass them on my computer, can it be done? Or is there any place to download them? The charts are the following
ESP10HSAT01.DBA
SD31P01TIN02.DBT
SDEWM009TIN02.DBT
SDEWM228TIN01.DBT
Vovan20   08-Jan-2025 13:28
I've installed TZ Pro 4.2.0.132 everething worked fine. Downloded and installed charts via Map Manager 2.7.1. But after 3 days TZ hangs on entry. I have a window to select Route making or Navigation and on whatever I choose it flashes initial picture with logo for a second and then cuts off. Where should I dig?
MiguelAC   11-Jan-2025 08:14
hi everyone
I installed TZ4 on a new machine, blocked de host, generated a few valid TZ, but when I input the SC and calculate AC it does an error
Is a new machine so I not understand why
I tried to uninstall and reinstall but SC still being the same and still doing error
Please I need help with this
rudolf   14-Jan-2025 23:44
Здравствуйте. Дайте пожалуйста код от карты SDVJENM299SMAP28.dbv для TZ 3 и 4
edgar007   16-Jan-2025 20:14
For those who looks for answers. TZ and keygen works fine on Win 11. But due to the fact that win 11 is crap, I returned to win 10, where I have encountered problems with keygen. After one day of pain, I can confirm keygen to work on win 10 x64 Home edition. Pro edition does not work with keygen. Hope this helps. Cheers
4logo4   17-Jan-2025 08:05
edgar007, Don't be silly. Everything works on Windows from version 7 up to and including 11 all editions.
edgar007   17-Jan-2025 10:55
4logo4, unless you have tried to install TZ on every version of each Windows from 7 to 11. And keygen wasn't giving error on any of editions. If not, you're a scam. I told what I have ecountered. There was some people having same issue. Go drink something for brain tumor
4logo4   17-Jan-2025 17:17
edgar007, Dear, I say again, TZ and keygen work on all versions and editions of Windows from 7 to 11, the only thing that may not work is brains.
kdim0915   23-Jan-2025 01:50
Musel, we all know there is a way but we can't find this way so stop saying the same again and again my friend.. we understood that you are the master of cracking, either show us the easy way or just stop.. we are fishermen skippers or whatever not the anonymous hackers
7
The time now is: Today 23:01
