Frost777   12-Nov-2024 02:29
Здравствуйте а можно установить на лицензионную версию , модуль с активатора ?Интересует модуль PBG
Hello, is it possible to install a module from the activator on a licensed version? I am interested in the PBG module
irtthuy   12-Nov-2024 04:58
Please help me with UC codes for TZ 4 PRO:
SDVJASM214MAP25
SDVJASM205MAP25
SDVJINM203MAP26
SDVJINM201MAP25
SDVJMEM204MAP25
Thank you very much !!!
recycle   12-Nov-2024 08:56
irtthuy,
105242Please help me with UC codes for TZ 4 PRO:
SDVJASM214MAP25
SDVJASM205MAP25
SDVJINM203MAP26
SDVJINM201MAP25
SDVJMEM204MAP25
SDVJASM214MAP25 :: D8BB7479993ACE8A25D9
SDVJASM205MAP25 :: 29BD6D581274BE2F25D5
SDVJINM203MAP26 :: F0F3F3EE61DC89E8263C
SDVJINM201MAP25 :: 46B65DDAE0A5448C25A6
SDVJMEM204MAP25 :: B9AC304B3E1BBACE25A9
Windsurfer   12-Nov-2024 23:37
Please help me with UC codes for TZ 4 NAVI:
WVJEMM076MAP26.1 SDVJEMM076MAP27.dbv
WVJEMM112MAP26.1 SDVJEMM112MAP28.dbv
Thanks in advance!
TrailblaZeR-Max   13-Nov-2024 03:16
Windsurfer,
Пробуй:
WVJEMM076MAP26.1 SDVJEMM076MAP27.dbv :: 5AF04324B5F59014272E
WVJEMM112MAP26.1 SDVJEMM112MAP28.dbv :: D5DA4B9B82470EFA2817
C4ptainHadd0ck   17-Nov-2024 16:19
I manage to fully install TZ 4 and charts.
The Maxlic V4 doesn't work for generating unlock codes for the charts, when I select a chart through the "buscar map" button, an error message pop up.
Instead, I have to use the map manager which works great.
Since I've applied the block host file, do I still need to avoid being connected to internet or now it's safe? I've decided to block the app by setting up a rule in my firewall (is it useful or just the block host do the trick? )
Cerrias   19-Nov-2024 22:56
Lucio666 uninstall TZ, manually delete files from the following paths
C:\Users\yourusername\Documents\Temp\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
C:\Users\yourusername\AppData\Roaming\Temp\{6f3e96c64-64f325-12ce-bhc1-08102bf10318}
C:\ProgramData\CrypKey\{4d36e96c-e325-11ce-bfc1-08002be10319}
C:\Users\yourusername\AppData\Local\Temp\{5e3e96c-e325-11ce-bfc1-08002be10319}
C:\ProgramData\Temp\{8f3e21c64-63f325-12ce-z5g1-081999f10318}
after this restart the computer and reinstall TZ
Good luck
Vittac   20-Nov-2024 10:46
Qualcuno ha il generatore di codici per sbloccare modulo radar e ecoscandaglio su mfd suzuki smd 12' o 16' (Furuno tzt2)
Grazie!
costellon   24-Nov-2024 21:14
Hi,
Excellent site, many thanks for the uploads through the years.
I have installed Timezero on 2 different pc's. One installation went perfectly but the second installation will not get me past the SC generation in Timezero. When I enter the TZ and Timezero generates the SC it takes literally over 20 seconds to do so (very very slow) and always displays the same SC code - regardless of how many times I uninstall and reinstall the program - it still gives the same code - even regardless of the TZ. When I generate the AC in the keygen and enter it into Timezero and press activate the page disappears/ closes. I have even tried typing the codes rather than cut and paste.
As I mentioned, the first installation on Pc number 1 went perfectly - Timezero generated the SC immediately and randomly with no problems.
I have used the same settings for both installs - disabled LUA, defender off, firewall off, all security off and checked and re-checked. Exactly the same settings but with 2 different outcomes. I have deleted remaining files as suggested, even manually updated host file .... nothing - it is still the same.
Processor Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz 2.70 GHz
Installed RAM 8.00 GB (7.58 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 10 Pro
Version 22H2
Installed on ‎09/‎09/‎2020
OS build 19045.5011
Experience Windows Feature Experience Pack 1000.19060.1000.0
Can someone please offer some advice ?
Many thanks
The time now is: Today 11:20
