Mbungurz   17-Oct-2024 12:14
I'm trying to install it, installation successfully committed, after input AC code and hit NEXT button , tz appears loading with Exiting word, and the closed
Try again, go to Activation, after AC code it keep exiting, is there I do wrong ? What can I do about it
help
recycle   17-Oct-2024 12:21
maxd2007, SDVJENM604MAP24 = UC E3D856C360638E6B2436 ( Russia - Russian Lakes, Production Date = 04-04-2024 ).
recycle   17-Oct-2024 16:15
ethos, = SDEM112FISHMAP01 = UC 30FDC7E35CEDE9250188 ( South Mediterranean Sea and Aegean Sea, Production Date 07-08-2015 ( FISHING ) ).
Artem2930ARH   17-Oct-2024 20:18
Всем привет!
Выдет ошибку в калькуляторе AC, подскажите, вопрос как ниубдь решили? спасибо.
Mbungurz   18-Oct-2024 14:32
104608Всем привет!
go back to page 30 and read carefully there is someone already answering this question
voltolik   18-Oct-2024 18:57
Привет!
кто нибудь сталкивался с проблемой - когда выделяешь судно, то раньше его картинка из Маринтраффика открывалась, а теперь пропала :(
только словечко - "testing". может подскажите, плиз
grnikolis   23-Oct-2024 13:17
Hi
I managed to install the software but i am having trouble unlocking the charts i downloaded.
The unlock tool works for the TimeZero software but when i try to open (Buscar Map Key) to find the chart key to unlock, the unlock tool crashes. What shall i do?
I need the unlock keys for
SDVJEMM017MAP28.dbv
SDEM112FISHMAP01.dbb
SDVJEMM111MAP27.dbv
thank you
mimoza051164   24-Oct-2024 19:36
bonjour; comment faire pour avoir TZ V4 originale MAXSEA TIME ZERO. pour télécharger la météo y comprie la chlorophylle.
merci.
noael   31-Oct-2024 01:51
Hi,
Im looking for a few codes for those maps:
SDVJEMM076MAP27.dbv
SDVJEMM111MAP27.dbv
SDVJEMM112MAP28.dbv
SDVJEWM228MAP27.dbv
Maybe I did not see the codes somehow the search did not give me the results I was looking for.
If someone could help me it would be a huge help. I’m very happy this site and community exists.
Cerrias   31-Oct-2024 09:34
104953Hi,
SDVJEMM076MAP27.dbv
SDVJEMM111MAP27.dbv
SDVJEMM112MAP28.dbv
SDVJEWM228MAP27.dbv
SDVJEMM111MAP27 Pro: E3B481D0B6D74B21273D; Nav: DE779E078968D46A2786
SDVJEMM112MAP28 Pro: E71D3B864DC45CC528BE; Nav: D5DA4B9B82470EFA2817
SDVJEWM228MAP27 Pro: 0A73DD26FF8EF19A276D; Nav: 5C43BBCBF098095527C0
noael   31-Oct-2024 23:01
Cerrias,
I did just notice there are also ultra wide maps. Can you tell me how they compare to the more narrow ones? Also f they are good I would be also interested in getting this one unlocked:
SDVJEMM017MAP28.dbv
Cerrias   01-Nov-2024 01:29
104995Cerrias,
SDVJEMM017MAP28.dbv
Pro: 87089637BDF1EAC42806
Nav: 3EBF55DDC7F24DE128AF
The time now is: Today 06:56
