istinniy2012   01-Oct-2024 09:42
Да как вы генерируете АС код?!?! Что я только не пробовал - кейген не генерируется. Error постоянно пишет. У меня одного так???
yemaya1   01-Oct-2024 12:51
¿Alguien puede ayudarme con un enlace para descargar MapManager 2.7.1.0? Todos los enlaces y publicaciones anteriores que he buscado en este hilo ya no funcionan.
samsunlusamet   02-Oct-2024 15:11
Hello,
MaxLicV4Pro activation creation programs are not working anymore? I write SC but AC code is not created. It gives an error. What is the reason?
samsunlusamet   09-Oct-2024 22:40
senseik, Yes, I found what caused the problem. After installing Timezero, you open it and perform the licensing process, let the internet of that computer be off. If the SC code does not accept the first Serial license you create and write, the license is blocked due to the internet.
* Activate the show hidden files option on the computer. Go to my computer/Local disk C: / App data / Cyrpto folder. There is a license file for Timezero there. Delete it. Create a license again with the Key program and activate the program. Then the SC code will be created.
The time now is: Today 06:56
