khalidtantan   22-Jul-2024 15:35
hello brothers please help mi wich charts give image graphique satellite verctor or raster like google earth image thinks for help
Porker   28-Jul-2024 17:14
Leobardo, Thanks that worked well. SDVJEWM226MAP27.dbv had a map key of 0000EADFCB354459 and I was expecting SDVJEWM226MAP28.dbv to be 0000EADFCB354460 but that doesn't work with the keygen. Has the map key sequence changed? and do you know what the map key is for SDVJEWM226MAP28.dbv so that I might calculate the mapkeys again using the keygen.
Musel   28-Jul-2024 21:26
They are hexadecimal numbers, so the number after 59 is 5A, not 60.
MK: 0000EADFCB35445A
UC: 564958435714EA0A28C9
zorrua   31-Jul-2024 17:09
Hello,
Every time a start the TZ app, it ask for a UM code, I generate with the keygen and access, but this is avery start.
Is possible to configure to not ask every start?
Thanks and regards.
zorrua   01-Aug-2024 16:12
Musel,
Thanks Musel, and how could I block the Internet access? Disconnecting the wireless?
Is it possible to block only the TZ app?
Thanks and regards.
tomado ®   01-Aug-2024 17:30
zorrua, Good day,
go to C:\Windows\System32\drivers\etc , and edit the file Hosts with Notepad
Add the following Lines to the Host file :
127.0.0.1 login.mytimezero.com
127.0.0.1 extranet.mytimezero.com
127.0.0.1 weather.mytimezero.com
127.0.0.1 tracking.mytimezero.com
127.0.0.1 share.mytimezero.com
127.0.0.1 usersobjects.mytimezero.com
127.0.0.1 logmachine.mytimezero.com
127.0.0.1 download.mytimezero.com
127.0.0.1 mytimezero.com
127.0.0.1 www.nobeltec.com
127.0.0.1 www.maxsea.com
Save the hosts file .
check That it Is not saved as a txt file, it should be File format.
Musel   01-Aug-2024 20:37
Or you can have it fully operational, just by modifying some libraries.
These WEB give the clue.
It is compiled in C# and is easy to modify.
lorenbr6   02-Aug-2024 18:28
AYUDA!!
Cada vez que abro TimeZero me sale para poner el codigo UM y no se guardan las cartas náuticas. Alguna solucion para que no tenga que estar poniendolo siempre???
The time now is: Today 23:12
