JavaDK   22-Oct-2015 14:57
Hint to unfreeze......
This sim needs to be running in a 32bit enviroment, otherwise it wont unfreeze.....
However the link for the download files seem to be missing/broken atm ?
wenewifi   23-Oct-2015 17:57
helllo, how do I save or load initial conditions so as to be able to simulate with this software....i have tried all i can to but, it tells me to load initial conditions and then simulate
Guest   24-Oct-2015 02:02
Im running the sim on a Windows 10 x64 systen and it works fine, including freezing and unfreezing when I tell it to.
Cdt35   27-Oct-2015 02:12
Hi,
Sorry to ask but...I can't find where to download the simulator on first page of the topic !!
Thanks for advice,
niessouh nassah   16-Dec-2015 16:41
10689Hi replaced simulator.exe from daemon to Neptune BIN during .
During the installation do I have to select Custom????? If yes do I have to install all files or only the software???
In my case the result is :
The program open but only the but only the mimics :
F1 start does not work it remain in F2 freeze ,
No possibility to have any volume
Many thanks for any help.
PS Do I have to stop the antivirus??????
pls any help regarding the floating license or if u have the hardware license
thks for help
niessouh nassah   16-Dec-2015 16:45
pls sir help me with the instructions on how to instal in a windows 7 64 bit
i already download it but after setup the simulator it doesnt work
sir i need ur help please
tamtam sa cebu   21-Dec-2015 21:50
Everything works fine on my Windows 10 64-bit environment except for most users had a problem with--the VRVIEW(only SHIP's FUNNEL CCTV is working). just Key in your HOME key for you to start.....by the way, i couldnt load a single scenario, how can i load one? I have scenarios in .cab format (not in .zip)
Alexandru888   11-Jan-2016 15:52
I couldn't get it work, when i tried to replace the simulator.exe with other simulator.exe it gave me error "Missing argument: -p <plant path>, how do i fix this ?
Thank you !
Guest   11-Feb-2016 01:54
Hello, Thank you for file! It works but I couldn't connect diesel generator to main bus bar. Everything seems okay and ready button is lit but when I click on the CONN button nothing happen? why does this problem occur?
http://postimg.org/image/47qq7zfjh/
The time now is: Today 01:45
