Vokoloven   18-Jan-2015 18:26
9631Thank you Vokoloven, I found it, all working properly now :)
Very nice(: if u have more question u can write private message(: click "+" if i help u(:
GryphonA   26-Jan-2015 14:50
Hi all,
I have a question for anybody may answer.
I have got a copy of the WORLD CHART FOLIO TX-97 Main and Auxiliary Collection DVD Issue WF 65 Year 2014 which in the case can be shared with you accordingly.
Is it there any way how to make install this latest chart world folio into the NS 3000 ECDIS-I ???
As far as I Know there should be a modification of the license.dat file.
Any help...
Thanks
GryphonA
Vokoloven   29-Jan-2015 14:52
9756Hi all,
Any help...
Thanks
GryphonA
Change time on your PC. Or use special programs. so can u give http:/ for u folio?!
GryphonA   31-Jan-2015 13:44
9819
9756Hi all,
Any help...
Thanks
GryphonA
Hi Vokoloven,
the problem seem to be the license itself.
You can load the world folio 65 but the Transas NS will not install any charts with present license expiring late sept. 2010.
We need to find a solution to get new modified license which will expire at least 26 January, 2015 (date of issue of the TX-97 WF 65).
I'll revert asap with torrent link for downloading.
Anyone can help us with coding the license will be very appreciated!!
Thank you
GryphonA
Vokoloven   03-Feb-2015 16:38
9885Подскажите пожалуйста, где можно найти актуальные license?
на что именно?
spb-domkrat   04-Feb-2015 16:55
9911
на что именно?
На Navi-Sailor 4000
При запуске программы ругается, что не подходят права
Vokoloven   12-Feb-2015 22:19
9935
9911
на что именно?
На Navi-Sailor 4000
Запускать файлик не забываете?
Forsa   14-Feb-2015 21:58
Подскажите пожалуйста,установил карты,но не показывает глубины и названия портов.
marko_1   02-Mar-2015 15:32
Hello everyone!
I have problem with installing charts.
Can someone please write step-by-step tutorial.
When I try to install with wizard or advanced, installation fails :/...
cnn   03-Mar-2015 14:35
Transas Navi-Sailor 4000 ECS v 1.11.005 [2008] + TX97/WF 43-44
I can't download this file. Pls tell me how to download. Thank you very much
Guest   05-Apr-2015 11:49
hi, tried to install transas navisailor 4000 and theres an error that says
"There is a problem with this Windows Installer Package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action InstallGuardantDrv.F24CC4E7_9AC3_4291_987E_D..."
I was using windows 7 x64bit in my laptop.
I dont know what program should i install to run this navisailor 4000.
ANyone can help?Thanks
junizar   05-Apr-2015 11:51
jericdave   12-Apr-2015 17:33
i cant open chart assistant ,.,. error says cant itialized database, reason : cant create time client, server does not exist
Vokoloven   14-Apr-2015 14:20
11314hi, tried to install transas navisailor 4000 and theres an error that says
Такого нету все на старом добром XP
The time now is: Today 22:27
