Guest   24-Sep-2022 17:10
Have anyone managed to install TimeZero Navigator in an ARM based machine?
The install completes fine but TZ will not Activate with the AC code from the generator
(Warning T0-0x00000009)
Your license is no more valid or active.
License service returned the following internal error :
-7
AUTHORIZATION BAD SITEKEY CRC
This CAN BE A NORMAL EVENT if your license simply expired or has been deleted.
tomado ®   24-Sep-2022 18:25
Guest, Good day,
Go to C:\ProgramData\CrypKey\Licenses and delete the folder containing the serial key.
Try again with another SC AND AC licence generated with the keygen.
CaptJack   26-Sep-2022 17:47
tomado, Thank you for your suggestion.
Unfortunately it did not work. Still the same. Could the sitekey gen differ between ARM and Intel machines?
-7
jcm0803   27-Sep-2022 06:19
skipper3362, thanks, timezero has installed.but no chart show. i want konw how do download chart data file. thanks
Guest   24-Oct-2022 20:21
skipper3362 where do I have to register? and where can I download the package?
Gian007   25-Oct-2022 18:23
It does not start ! I am sorry cause i really like that software.
I generated the AC code
I paste the AC
A click Activate.
Timezero does not start.
qazi.faisal   19-Nov-2022 03:09
I said sir , how can i download the charts its showing crack version , when i go to website timezero and donload the chart they ask for a serial key number where i can get those keys
eleet   23-Nov-2022 11:32
Hello guys.
First, thanks for the up-loader effort for this good program. Everything is working smoothly.
I have one question regarding the overzoom text and missing the content of the map. I have download the Africa - West map - SDVJAFM210MAP21, i have put the corespondent UC but still i cannot see the content of the map. Maybe somebody experience same issue.
Is strange that first time when i installed the software on windows 8.1 it work. Now on windows 11 the software is working but i m not able to fix this issue with the map. Appreciate your advice. Thanks
The time now is: Today 20:48
