Nhism   14-May-2025 18:05
matrixdu, I finally found this Topic again. Sorry I just found it now. So to get the location of a port or a ship, we have to download another software called MaxSea or CMap, right sir? Because I really just learned about this software. Hope you can help me. And if the connection is successful, can we see any location on that Chart? Because I also don't know how to add a chart. I read in another topic that there is a code for that chart but I don't know how to use it.
matrixdu   14-May-2025 19:18
108617matrixdu,So to get the location of a port or a ship, we have to download another software called MaxSea or CMap, right sir?
Download / instal Maxsea TZ 4.2
yes but you have to connect gps
Download Map Manager
sam_16_09_   17-May-2025 07:56
Perdon lo poco de conocimiento que tengo pero el block host no me funciona siempre me pide el UM necesito alguien que me oriente o que me diga que hago mal en ese caso
derekcarton   22-May-2025 07:56
need uc for wvjnam024map27.1
how do i download map manager? i can not find any place to download from
juvtc   28-May-2025 21:48
Bonjour, savez-vous où je peux télécharger des cartes pour maxsea V4 ?
Sur le site officiel les cartes sont de 2025 et les codes ne sont pas disponible
Ou alors avec vousle code pour la carte SDVJEMM076MAP28.dbv ?
matrixdu   30-May-2025 21:42
Rachid5511,help yourself
Attachments Export 30.05 2025.xlsx (548 KB, Downloaded: 119 times)
3
yodass   07-Jun-2025 20:39
Hello , thanks you for all
I need the code UC for : SDVJEWM226MAP29.dbv
: SDVJAUM001MAP26.dbv
this new map , dont find in XLSX
Thanks you
zus   14-Jun-2025 09:58
madthinkpad,
I don't know if it works but a guy on the web asked me $300 for a single PC. Original costs $500 for two PCs!
ianvan112   28-Jun-2025 10:40
Hello Everyone,
I tried to install Timezero Pro after I use the AC given by the software TZ prov4 and I input it in Maxlicv4pro, the SC gives me error.
Please help me to solve this. I already tried to uninstall and try it again. same AC given by the software. so the SC again was error..
Thanks in advance!
ianvan112   28-Jun-2025 13:29
Please help me!
If I have license Timezero Navigator v4 (not cracked).
It is possible to use map manager 2.7.1 to update the chart of the license??
Thank you in Advance!
The time now is: Today 23:23
