John Ai   07-Oct-2023 11:01
Здравствуйте, мой картографический менеджер больше не загружает карты. Постоянно вылетает и перезагружается, но не загружается. Пожалуйста, помогите, если у вас есть идеи.
Спасибо
gull-hater   16-Oct-2023 13:22
I just wanted to post and say thanks to the up-loader. An incredible job and service you are providing!
I got everything up and running by following the instructions.
I do have one problem though and would greatly appreciate if anyone in this community can help.
My issue is regarding the PBG when in the Fishing tab. I want to change 2D depth information to hardness? Timezero instructions say to right click on depth shading but nothing appears.
I have imported an old Maxsea V12 ptz file recorded using a seascan unit so the information should be there to access, but the issue seems to be more that the option does not exist.
I added and installed all the provided modules so I don't think that is the issue. Unless it requires a newer module not included with this upload?
I spent considerable time looking up official Timezero documentation and can't get a clear answer to my problem and so I am hoping someone here can assist?
HAISEAMEN   16-Oct-2023 14:33
4logo4, my friend give to me only Map key chart SDVJASM001MAP23.dbv, I'll find Uc Code ,because i use Timezero Navigator v4.2.0.133
HAISEAMEN   16-Oct-2023 14:37
tomado, my friend give to me only Map key chart SDVJASM001MAP23.dbv, I'll find Uc Code ,because i use Timezero Navigator v4.2.0.133
insorrow   17-Oct-2023 19:07
Гость, Качайте по этой ссылке https://download.mapmedia.com/v...604MAP20.dbv.zip
92978
92951Добрый день.
Есть у кого нибудь US для SDVJENM604MAP22.dbv ?
В активаторе не нашел, к сожалению.
Или векторная карта SDVJENM604MAP20.dbv (более ранняя), на которую есть US в таблице..
Вот карта https://download.mapmedia.com/v...604MAP20.dbv.zip
tomado ®   17-Oct-2023 19:22
insorrow, Good day,
Download MAPMANAGER 2.6.0.0 and make an update you will find a post that explains how to do it in the first pages.
SDVJENM604MAP22.dbv UC Pro version : 61C99C2E568E965C225D UC Nav version : EFAC36AD2F0BBE752206
geni1987   19-Oct-2023 23:35
tomado, hola marineros,
busco algo de info nescesito intalar esta carta en mi timezero WVJEWM228MAP24.1 pero no localizo en uc ni el codigo para generar el uc,
alguin tiene info¿?¿?
un saludo y buena marea
The time now is: Today 11:58
