Guest   03-Jul-2023 02:49
Не получается активировать программу, сделал все по инструкции. После последнего пункта программа просто вылетает и при повторном запуске снова просит активацию, помогите пожалуйста, что сделать?
EnigmaII   14-Jul-2023 19:04
Hello, Can Any one Help... I cannot get TimeZero Professional v.4.2.0.132 from this post to work... I cannot generate an AC Code with the provided KeyGen.. only returns "error".
I have tried clean install etc. but always the same result.
I have successfully installed TimeZero Navigator V4 from this site, but would really like to get Pro version operational...
Any help would be very much appreciated.
Thank you in advance
11
alinwar   16-Jul-2023 15:46
Приветствую всех, кто-нибудь знает как узнать user permit? Официальные пути это при покупке модуля и активации через интернет либо по email. Но может быть можно вытащить его из программы. Во всех версиях если даже активировать модуль то User Permit не показывает.
fanso   05-Aug-2023 13:32
Good morning to all.
I was using the the Time zero V3 without problem.
I download and install the TZ pro V4 and install it but is asking me the UM code for my TZ B1D4 D78C 0594 7923 0B.
Or if possible to send me the keygen for TZ pro V4.
Thanks in advance
Thanks in advance
Wabu   07-Aug-2023 02:37
matrixdu, And what does the column 'UCode' show in your Map Manager ? That is the important code which you'll need for map registration.
matrixdu   10-Aug-2023 13:54
Wabu, shows nothing as you can see on photo,it was working while ago ,off course it is important code thats the reason of my question.....
Sailor271047   13-Aug-2023 21:22
TZ Pro 4.2.0.132 seems to be working fine back, the problem is that the screen is full of squares of the crack names, can someone help me to sort this out! THANKS
The time now is: Today 00:58
