rene_ll   18-Nov-2022 15:23
Hello Friends
I have installed the Maxsea Timzero V4 Pro application. I'm using Windows 11. Every time I close and open the TZ program, wants UM code. Is there a solution for this? Is there a Crack Screen Fix patch for Maxsea Timzero V4 Pro?
Please Can you help me?
3
artursandulsky   23-Nov-2022 11:37
Anybody knows how to unlock soundings around Japan, all c-map charts have no soundings available around Japan and information on the charts that this is not navigational chart, please use paper Japanese charts. Thanks
Amaroid   26-Nov-2022 19:10
I also have a problem with Windows 11. After entering AC and clicking on the "ACTIVATE" button, the program crashes. Everything worked fine on Windows 10. Is there any solution to this problem ?
3
CaptJack   28-Nov-2022 20:03
noael, Did you find a solution to this?
I have the same issue with installing it on a MacBook M1 with Parallels Desktop.
I assume you are trying to install it on Windows 11 ARM version? I beleve its a problem activating an ARM based Windows vs Intel Windows
The install completes fine but TZ will not Activate with the AC code from the generator
(Warning T0-0x00000009)
Your license is no more valid or active.
License service returned the following internal error :
-7
AUTHORIZATION BAD SITEKEY CRC
This CAN BE A NORMAL EVENT if your license simply expired or has been deleted.
egaeloy   01-Dec-2022 19:30
Todo bien, pero cuando parece que arribamos a puerto, se lanza con alegría lla "boza AC" para poder acoderar, pero inmediatamente se rompe y ya no hay más inventos que hacer a pesar que se evitan por todos los medios y desde el inicio las nubes borrascosas (red).. Inmediatamente desaparece la intención en el horizonte con mucho pesar.
Mbungurz   18-Dec-2022 14:29
Yeah, the next thing after installation and adding chart is... How to get an weather, chlorophyll, etc. Is this possible to do?
The time now is: Today 00:49
