svmk3   04-Sep-2022 09:12
Не работает keygen. При попытке сгенерировать AC code, выдает ERROR.
kadoka   04-Sep-2022 23:37
hello
Software worked perfectly until today.When I opened I saw sign crack instead of charts.
I don't know how to resolve problem. help me
Best regards
tomado ®   05-Sep-2022 16:48
kadoka, Good day,
Delete it with Advanced Uninstaller PRO for exemple and try to install it again by following the precedure step by step .
It is important to execute "MX_TZ v4PRO_crack_SplahScreen" before the first use of TimeZero application
FUCKINGHELL   05-Sep-2022 19:51
tomado, I don't think Advanced Uninstaller PRO will delete all files, so using methive work-around .bat files is better way. First work-around to fix cracked screen and then work-around to block it via firewall and hosts.
3
tomado ®   05-Sep-2022 21:29
FUCKINGHELL, I am also using methive work-around .bat file
The issue is that you lose internet connection to TImezero .
MASTER PELUKIYA found alternative solution by using reverse enginnering software's , and i am trying to do same .
Do you have any idea about the file's to edit ?
FUCKINGHELL   05-Sep-2022 23:10
tomado, it is better to ask directly Пиратский флаг As far as I remember... blocking via firewall rules completely forbids Timezero internet connection and hosts solution blocks only connection to Timezero servers. I do not see any value in TImezero internet connection and have not investigated reverse engineering option.
aphix   16-Sep-2022 16:59
всем привет, я так понимаю про Баренцево, Карское и прочие моря, что на севере можно не спрашивать? их нет? спасибо.
ngiann   17-Sep-2022 15:24
Installed in Win 10, I added chart key , program seems to work but the chart is without details (just some generic shapes) . Do the chart need to be downloaded somehow?
ngiann   18-Sep-2022 00:09
tomado, thanks but the in the first link I can't find download option(only choice to buy), unless I miss something.
I already have the excel file so I can find the UC code of the map I'm interested.
May be it's obvious but I am stuck...
ngiann   18-Sep-2022 12:42
Sorry to say, but gpspower.net registration system is not working, it lets you to register but you never receive confirmation email so your account remains inactive. I tried with 3 different emails during last month.
I read that others have same problem.
So any links to gpspower.net for me is useless and I kindly ask if someone can copy the related info here..
ngiann   18-Sep-2022 20:48
tomado, thanks, now i can download desired maps.
As per gpspower.net i cannot send PM since i'm not active member.
3
The time now is: Today 22:02
