calicokiller   21-May-2026 07:29
Musel,
I know I’m late to the game, download the keygen in your other post but it’s different that the screenshot you showed. No place it put in the map for the unlock code any help would be amazing. Trying to bring back to life a tzt2 with a cmor map
calicokiller   21-May-2026 08:28
Musel,
thanos22   26-May-2026 14:33
jarod73260, salut, perso je n'autorise pas TZ a se connecter sur le site Time Zero via les options dans le log et sinon tu interdits les connexions entrantes et sortantes dans le pare-feu de windows. Tu as avancé concernant la version 5 de TZ ? merci pour ton retour.
phammanhlinh   26-May-2026 19:42
vty.yuriy, TKS U SO MUCH. 1 QUESTION PLS, I HAD THE PROBLEM. FIRST TIME INSTALL ALL WELL, BUT I REMOVED & INSTALL AGAIN THEN PROBLEM SHOW. I ALREADY INSTALL CHART FOLLOW U, IT FINE BUT CAN NOT SHOW IN THE APP. ONLY CRACK
The time now is: Today 16:18
