Cerrias   27-Apr-2026 22:49
113371Goodmorning to all. Is there any link for map manager v2.7.1 ? . Thank you
You have it in this same discussion a few posts before. You have to read the forum a little before asking.
jarod73260   30-Apr-2026 21:37
EnigmaII, I mean package to Install so i will be able to bypass security and restriction.
I already own procedure and knowledge for v4.2. I reverse appa and keygen
Nhism   01-May-2026 10:57
Hi everyone, I wonder if anyone here has encountered this error before?
I tried using the "Launch Routing" function in TimeZero, but it showed an error as shown in the attached image. I also tried setting other parameters as requested, but it still didn't work.
I hope to receive advice from you all.
Peace
Leobardo   01-May-2026 18:43
yaneiscvs,
THAT REGION IS NOT ACTIVATED IS BETTER THIS ONE :
SDVJRSM002MAP28.dbv-----------9E9332DDC5F2944E280D
GOOD SAIL
Rokateli   02-May-2026 13:47
Hi everyone,
I’m currently trying to connect a transducer to TimeZero Professional via a DFF1 sounder, which is compatible with both the transducer and, in theory, with TimeZero.
However, I’m running into an issue: although everything is powered, connected, and responding correctly to ping, TimeZero does not detect the sounder device.
I have followed the setup instructions provided in the manual https://userguide.mytimezero.co...DFF1_Sounder.htm but the problem persists. I have also confirmed that the Furuno Sounder module is enabled in TimeZero.
Has anyone experienced a similar issue or could suggest what I might be missing?
Thanks in advance.
jarod73260   02-May-2026 19:28
Rokateli, The "Furuno Sounder Module" needs to be unlocked prior to configure a Furuno Ethernet Sounder in TimeZero with the correct UM code.
The time now is: Today 16:18
