xinit0   02-Mar-2026 22:39
artursandulsky, Close everything maxsea related, even the keygen. Search for a folder called cripkey or criptkey, usually on appdata/local or roaming, cant remember now. Delete the folder and try again.
sebagutierrez   12-Mar-2026 18:09
Hi, has anyone been able to install the maps? I installed the program correctly, but not much information appears.
hchmelg   15-Mar-2026 04:47
mustaphabenisaf,
SDAF210FISHMAP01.dbb
SDVJEWM010MAP31.dbv
SDVJEMM112MAP31.dbv
SDVJEWM228MAP30.dbv
SDVJAFM210MAP28.dbv
SDVJAFM005MAP28.dbv
SDR20P01MAP11.dbr
SDR46P03MAP18.dbr
SDR46P04MAP18.dbr
SDR46P05MAP18.dbr
SDVJEWM010MAP31.dbv
SDVJEMM112MAP31.dbv
SDVJEWM228MAP30.dbv
SDVJAFM210MAP28.dbv
SDVJAFM005MAP28.dbv
SDR20P01MAP11.dbr
SDR46P03MAP18.dbr
SDR46P04MAP18.dbr
SDR46P05MAP18.dbr
hchmelg   15-Mar-2026 04:48
SDVJEWM010MAP31.dbv
SDVJEMM112MAP31.dbv
SDVJEWM228MAP30.dbv
SDVJAFM210MAP28.dbv
SDVJAFM005MAP28.dbv
SDR20P01MAP11.dbr
SDR46P03MAP18.dbr
SDR46P04MAP18.dbr
SDR46P05MAP18.dbr
Nezar   16-Mar-2026 14:59
I installed it on a new computer. Everything works, but the map itself doesn’t display — it’s completely white. However, all the markers that come with the map are visible, and I can turn them on and off. What could be the problem? Thank you!
Attachments (5 KB)
PBSophia   17-Mar-2026 10:00
Hi All,
None of the UC codes generated in Map Manager seem to work on TZ Nav 5. Has anyone been able to install the maps into the latest version of TZ Nav?
Thanks,
Will
Cerrias   17-Mar-2026 16:45
112791Hi All,
Thanks,
Will
Have you updated MapManager?
PBSophia   18-Mar-2026 02:37
Cerrias,
112802
112791Hi All,
Thanks,
Will
I'm running map manager 2.7.1. Is that the latest?
Thanks
Alivye   18-Mar-2026 09:02
Доброго дня, не могли бы пожалуйста подсказать другой UC на
SDVJEMM017MAP31.dbv
5867E17645ECC2393127 - НЕ подходит
Буду очень благодарен
akramesaidi   21-Mar-2026 22:01
Sate, I started entering the numbers from the following table. When you write the code, start immediately after sc
MPI   25-Mar-2026 15:19
Hi, how can we find MAP KEY to generate UC map code ?
Also I run it on windows 11 pro. install went fine but when I launch the software, it starts then close just past the splashscreen. I do run blockhost.cmd in elevated command...
Any ideas ?
Aves   26-Mar-2026 10:32
Please if anyone has the code for the map:
SDVJRSM013MAP03.dbv
Подскажите что за MapManager, где его найти.
The time now is: Today 18:34
