44U   29-Nov-2025 04:17
sorry sir..
if you have,i need maps and UC tz navigator v4 this maps .SDVJINM205MAP28. SDVJINM203MAP28 pleace...
zeimer   30-Nov-2025 00:36
Adrian7137,
1. Download and open OpenCPN
2. Go to settings, plugins, and enable the GRIB plugin
3. On the left, select the grib plugin (weather arrow symbol), then click the @ to start a download request
4. Select email, mailto: saildoc
5. Select the model and settings you want (GFS, ECMWF etc), then click send. It will create an email with the correct request code to send to SailDoc. Then send this email.
6. Wait a minute and you will receive an email with a .grib file from saildoc. Import it into TimeZero in the menu Import weather file
That's a bit of a process but then you can do weather routing and all in TimeZero :-)
3
skitaletc-1963   30-Nov-2025 10:14
Всем привет!!!! Ребят, есть у кого ключи к этим картам??
SDVJANM204MAP07
SDVJRSM013MAP03
Если есть, поделитесь пожалуйста. В "MapManager" их нет.
За ранее благодарю.
didi01   04-Dec-2025 01:07
SLGTR27, before you start to install turn off you internet and don't forget to turn on crack splash screen folder
joshoes14   06-Dec-2025 15:32
Hi everyone, does anyone have the UC code for ta pro 4 for :
SDVJEWM226MAP31.dbv
If someone can help me I would appreciate,
Thank you
nono14   07-Dec-2025 01:02
bonjour a tous je recherche les UC de ces 2 cartes pour time zero v4 pro
SDVJEWM226MAP31
SDVJEMM076MAP30
merci
The time now is: Today 11:58
