wasya12   14-Oct-2025 14:00
Please, help me with SDVJRSM221MAP02.dbv.
When i trying to get UC code for this map by using MaxLicV4Pro_R5, "Buscar Map Key" button, I am having error System.IO.FileLoadException.
What should I do?
And another question: where can i get Map Manager?
JpWrx   18-Oct-2025 14:05
Quelqu'un le crack pour la version 5?
car dernière version que j'ai TimeZero Professional v4.2.0.138
Merci
JpWrx   21-Oct-2025 16:28
Recherche Uc car impossible avec MaxLiv
pour ces cartes
SD28P01CRT02.dbc
SDEW227FISHMAP01.dbb
SDR25P01MAP16.dbr
SDR25P02MAP16.dbr
SDVJEWM225MAP26.dbv
SDVJEWM226MAP30.dbv
SDVJEWM227MAP30.dbv
SDVJEWM228MAP29.dbv
SDR46P01MAP18.dbr
SDR50P05MAP15.dbr
Merci
Markese   26-Oct-2025 19:59
Hi guys, once I've installed TZ v4, can I connect to the internet without the risk of my cards being blocked?
discreet   27-Oct-2025 00:36
Quick question, Is there a way in Windows (Windows Defender or other tools) to prevent TimeZero from accessing the Internet while still allowing it to be discovered on my local network (so it can see my Furuno NavNet) but avoid to been discovered as a cracked version? I need the machine to keep Internet access for other apps, but when TimeZero or the Crypt key is left open it seems to try to reach the Internet. Does someone know how to do it? thanks in advance!
JpWrx   27-Oct-2025 08:24
Markese,
Yes, that will mean that.
You need the MaxLicV4Pro software to crack the serial number.
Uncheck Internet access in the TimeZero menu.
Then you need the files:
Block Host
TZ_PRO-NAV_Firewall_V4
TZ_PRO-NAV_Hosts_V3
I set all three and I'm completely fine.
And then you can reconnect to the internet.
JpWrx   27-Oct-2025 08:31
discreet,
Disconnect from the internet
Uncheck Internet access in the timezero menu
It is the TZ_PRO-NAV_Firewall_V4 file that will ask you how you choose to connect via the internet and leave the NAVNET network connection in addition
Block Host
TZ_PRO-NAV_Hosts_V3
discreet   30-Oct-2025 01:05
JpWrx, HI thanks for your message the only thing is that I don´t have those 2 files with me. I´ve search them but can´t find them on internet. in this link theres only the MX_TZ V4PRO_crack_SplahScreen, then the Block Host.cmd and then the keygen. can you please someone share those files? I havent´seen them before.
thanks in advance
Markese   01-Nov-2025 22:07
Hi everyone, thank you for your time and responses. I'm going to ask another question: can satellite photos be used offline? Perhaps by downloading them from the official website or Google Maps?
The time now is: Today 15:58
