kuko76   11-Sep-2025 00:34
87895It does not work.
It can not calculate the AC code as you can see in the pic attached.
The same thing happens to me, the AC gives an error. help me thanks
ronchuw   14-Sep-2025 13:19
Hello,
After updated my window yesterday, I can't enter TZ anymore. I have installed teamviewer on my pc. Not sure if it is affecting but I see teamviewer application icon in the TZ folder. Does anyone encounter this problem?
chavoco   14-Sep-2025 18:56
Hello
I follow all the steps but always sendme this problem, I reinstall but always is the same issue... please somebody tell wath can i do
hassan0080   14-Sep-2025 20:09
adrianperez919, Bonjour, mon cher frère. Tu dois formater ton ordinateur, car le logiciel Time Zero a infecté ton ordinateur par un virus. Tu dois désinstaller Windows et le réinstaller.
chavoco   14-Sep-2025 20:21
hassan0080,
Could you send me links to other generators for this version? I tried other codes from the same generator, but none of them worked.
chavoco   15-Sep-2025 19:06
Hello, I managed to install and register the program, but now I can't download the weather data and, most importantly, the chlorophyll. I would appreciate any help with this issue.
Thanks in advance.
kiwimen1   17-Sep-2025 03:16
Hello, I downloaded this version of TimeZero. I'm new to this and I want to add the weather. How can I do this? Can someone give me a tutorial on how to do it?
nugrohot   18-Sep-2025 01:53
adrianperez919, you don't connect to the internet then open tz... you have to open tz first then connect to the internet
chavoco   18-Sep-2025 04:46
hoang90, I'm ussing timezero ok, but isnot posible download the western, i can't do tratado... i dont know Whats is your issue
The time now is: Today 20:19
