ronchuw   26-Jul-2025 03:14
Good day,
My Timezero 4.2 after relaunch did not show any chart info, all downloaded charts need to reinstall again.
UMcode asked for everytime relaunch also
Can someone help me
hoang90   28-Jul-2025 10:45
TerryCG, bro à.many tks.i try to connect many times with ais wifi .it show connected successful. But i dont see signal coming.so now i need to set baud rate.38400
TerryCG   29-Jul-2025 01:41
109552TerryCG, bro à.many tks.i try to connect many times with ais wifi .it show connected successful. But i dont see signal coming.so now i need to set baud rate.38400
Can you confirm it successful or not? You can pm me
hoang90   30-Jul-2025 13:01
TerryCG, yes.can connect.but no need change baudrate. Lastime i try with tcp .not correct.we need connect nav net
CarlPort   30-Jul-2025 18:27
108965Hank08, right click on icon go to properties,open tab shortcut and from run choose maximised >apply>ok than try again
If anyone is interested in downloading the latest version of TimeZero V4 Professional more recent edition V4.2.0.138, which can be used under the same parameters already known in this Forum, the direct link to download the TZ Professional, as well to TimeZero Navigator V4 last edition, links below:
TZ PROFESSIONAL V4.2.0.138 LINK:
https://download.mytimezero.com...Professional.exe
__________________________________________________________________________
TZ NAVIGATOR V4.2.0.140 (RECREATIONAL) LINK:
https://download.mytimezero.com...allNavigator.exe
_____________________________________________________________________________________
Just copy the link in your browser to start the direct download.
Best regards
4
CarlPort   30-Jul-2025 18:37
109015Just to clarify:
The latest version mentioned above (V 4.2.0.138) can also be used to update the previous version that may already be installed on your computer (V 4.2.0.132), preserving the settings that have already been implemented.
Юнга
Just install it over your previous version, you will keep everything as before, but with the latest version, that's all ...
Regards
The time now is: Today 01:43
