Hb5276   02-Jun-2025 08:56
matrixdu, now I am off that screen as I tried one in another post, it hasn't worked please excuse my ignorance but how do I get back to that screen to add another UC and download chart
Hank08   08-Jun-2025 09:45
Hello, I need help, someone passes by that when executing the map manager2.7.1.0The program does not open does not let the data be seen. I would appreciate help thanks in advance
matrixdu   08-Jun-2025 10:01
Hank08, right click on icon go to properties,open tab shortcut and from run choose maximised >apply>ok than try again
CarlPort   09-Jun-2025 18:39
If anyone is interested in downloading the latest version of TimeZero V4 Professional, which can be used under the same parameters already known in this Forum, the download is included in the link below.
There you will find a PDF with the mentioned links for various versions of TimeZero Professional, including V5, which is not feasible at the moment, as well as V4 in version V4.2.0.138.
https://www.furuno.dk/media/gde...ional-500583.pdf
Or just copy the link below and paste it into your browser to start the direct download:
https://download.mytimezero.com...Professional.exe
Best regards
5
CarlPort   11-Jun-2025 20:35
Just to clarify:
The latest version mentioned above (V 4.2.0.138) can also be used to update the previous version that may already be installed on your computer (V 4.2.0.132), preserving the settings that have already been implemented.
Юнга
flomerlin   12-Jun-2025 20:20
Hi everybody, hope you enjoy your days at sea.
Please someone could help me to find UC codes for :
- SDR32P03MAP13
- SDR30P02MAP11
I usually use Map Manager but i only find old codes (for SDR32P03MAP09 / SDR30P02MAP08)
How do you do to find recent codes ? (I tried fonction / update on Map Manager... but it doesn't find SDR32P03MAP13...) Another brick in The Wall
Thanks !
Hank08   14-Jun-2025 03:31
Hello, a query that you use program to download the weather parts and load it in timezero? I used the zygrib but it no longer works, if you know any I would appreciate your help, greetings
Hank08   15-Jun-2025 03:52
Cerrias, Thanks, I already installed it but when I want to load the data in the timezero it gives me an error, I have to modify something in the xygrib file?
discreet   17-Jun-2025 03:15
Hi I´ve tried to insert the TZ serial Number after following all the steps carefully and once copied the SC code I got an error on the AC code. Can someone have the same issue? I´ve tried several times with no luck. I´ve used the lastest installer from TZ Professional v4.2.0.138 that I know works well with allt he cracks and files shared on this link. the only thing I haven´t done yet is to remove the block host file after the installation As I suspect I need to do it once I put all the serial codes right? thanks so much in advance!
The time now is: Today 05:31
