skipper3362 ®   17-Jul-2019 00:03
BOCA Suite
Version: v2.2.0.3
Developer: AVEVA
64-bit OS compatibility: yes
System Requirements: AVEVA Bocad Suite v2.2.0.3 / System Requirements
Operating system:
- Supports: Microsoft Windows 7 SP1 with 32-bit or 64-bit (Windows XP SP3 no longer supported officially).
- Minimum: Windows 7 SP1 32-bit
- Recommended: Microsoft Windows 7 SP1 64-bit.
Processor:
- Note: 64-bit operating systems (and 64-bit versions of AVEVA Bocad) require a 64-bit capable processor.
- Note: The relevant criterion for the performance of AVEVA Bocad is the processor cycle, not the number of processor cores.
- Minimum: Dual-Core i3 2GHz
- Recommended: Dual-Core i5 3Ghz or better
Main memory:
- Note: For an effective utilisation of more than 4 GB a 64-bit operating system is required.
- Minimum: 4 GB.
- Recommended: 8 GB.
Graphics board:
- Note: AVEVA Bocad uses the existing graphics board for the monitor representation (e.g. anti-aliasing on views) and to render the 3D model.
- Minimum: Onboard graphics.
- Recommended: Any dedicated graphics board, except onboard graphics, with hardware support of OpenGL 2.1 or above, and video memory of at least 256 MB.
Hard-disk:
- Minimum: SATA 250 GB (8 GB free for AVEVA Bocad-Installation)
- Recommended: SATA (at least 500 GB) as data drive plus SSD drive (at least 128 GB) for Windows and Bocad Folders).
Monitor / Notebook display:
- Minimum: Resolution min. 1280x1024.
- Recommended: 24" with 1920x1080 or better resolution.
Printer:
- Minimum: None.
- Recommended: Any printer/plotter with at least 1,200 dpi, with further specification (e.g. max. print-ing size) depending on your requirements).
Crack: Included
Description: steelwork design and detailing for the offshore industry AVEVA Bocad Offshore extends the productivity of AVEVA Bocad Steel with special features for the specific needs of this challenging industry sector. Together, these enable consistently rapid, high-quality fabrication and construction of all parts of an offshore installation, for on-time, onbudget delivery of a high-quality asset. A proven product with an unrivalled track record on the most advanced structural design projects, AVEVA Bocad Offshore can deliver value as part of a stand-alone AVEVA Bocad Steel solution or as part of an integrated AVEVA Plant or AVEVA Marine deployment. AVEVA Bocad Offshore is especially designed for the detail, design and fabrication of all forms of offshore structures. This dedicated software is ideal for use for all sizes of fabrication yards right through to the largest engineering contractors.
AVEVA Bocad Onshore:
Powerful structural steelwork design and detailing for the plant industry Accurate and detailed design is essential for efficient and error-free plant construction. AVEVA Bocad Onshore extends the productivity of AVEVA Bocad Steel with special features for the specific needs of the onshore plant industry. Together, these enable consistently rapid, highquality fabrication and construction of all parts of a plant, for on-time, on-budget delivery of a highquality project. A proven product with an unrivalled track record on the most advanced structural design projects, AVEVA Bocad Onshore can deliver value as part of a stand-alone AVEVA Bocad Steel solution or as part of an integrated AVEVA Plant deployment. AVEVA Bocad Onshore is especially designed for the detail, design and fabrication of all forms of onshore plant structures. This dedicated software is ideal for use for all sizes of fabrication yards right through to the largest engineering contractors.
AVEVA Bocad Roof and Wall:
Powerful structural detailing for efficient building design and fabrication Accurate and detailed design is essential for efficient and error-free construction of any type of engineering project. AVEVA Bocad Roof and Wall is a purpose-designed, powerful and flexible tool for the efficient, accurate 3D design of a wide range of building construction projects. Whether for light or heavy duty, commercial, industrial or architectural projects, AVEVA Bocad Roof and Wall is the ideal tool for all structural steel, cladding and glazing design needs. A ‘best-in-class’ application with an unrivalled track record in the Architectural, Engineering and Construction (AEC) industry, AVEVA Bocad Roof and Wall delivers unrivalled value as a standalone engineering solution or as part of an integrated AVEVA Plant deployment.
- AVEVA Bocad Tower:
Powerful structural detailing for efficient tower design and fabrication Accurate and detailed design is essential for efficient and error-free construction of any type of steelwork. AVEVA Bocad Tower is a purpose designed, powerful and flexible tool for the efficient, accurate 3D design of a wide range of tower structures, whether light or heavy duty, three-legged or four-legged, such as transmission towers, telecommunication towers, substation gantries and poles. A ‘best in class’ application with an unrivalled track record in the transmission and distribution industry, AVEVA Bocad Tower can deliver value as a stand-alone steelwork solution or as part of an integrated AVEVA Plant or AVEVA Marine deployment.
Additional info: AVEVA Bocad Suite v2.2.0.3 / Installation Guide
1. Download the software first and then unzip it.
2. Disconnect system access to the Internet.
3. Enter int\t52238\Bocad_2.2 and install the AVEVA Bocad software by running Setup.exe.
4. Enter the int\t52193\ABSI220 path and install AVEVA Bocad Steel Interface using the Setup.exe file.
5. Enter the updated folder and update the software by running the BocadPatch2.2.0.3.msp file.
6. Enter the Crack\AVEVA Licensing v1.3 folder and install AVEVA Licensing System by running Setup.exe.
7. Run AVEVA Licensing Client Configuration Tool from the C: \ AVEVA\AVEVA Licensing System\ALSClientConfigTool.exe path with Administrator access.
8. In the User Environment and System Environment section, complete the Server 1 values ​​according to the following pattern.
9. In the Port Number part number 4545 and in the Hostname field enter the localhost entry.
10. Click Save Settings and then click Close.
11. Run the AVEVA License System Console application from the C: \ AVEVA\AVEVA Licensing System\ALSConsole.exe path with Administrator access.
12. Enter the Start/Stop tab.
13. Click Start Licensing System.
14. Enter the Keygen folder and right-click on the Keygen.exe file and click Run as Administrator.
15. Make a file named lservrc.xml alongside the Keygen file.
16. Enter the Licenses tab.
17. Select the Browse option and give the file's address the lservrc.xml.
18. Click Install License File.
19. In the window that opens, click Start License File Installation.
20. Enter the Query/Config tab.
21. Make sure the RMS Server is green in the Query option.
22. Run the original software.
23. Sign in with your SYSTEM username and password XXXXXX.
24. The software is fully functional and can be used without any limitations.
Tips:This software has been fully tested with Cracked. .
- If you encounter an active & creation error, enter the Computer Name value instead of localhost, by right-clicking on the computer and choosing the Properties option.
- This software requires Microsoft .NET Framework 3.5/4.0 and Microsoft Visual C ++ Runtime to run correctly
- All files are compressed and repaired as much as possible I WinRAR is able to & be.
password www.p30download.com
aveva boca suite
Download [16 KB]
AVEVA Review 12 v.2.0.11 - AVEVA [2018]
Seafarer: The Ship Sim v.0.3.0.1797 (Build 23027061) - Astragon [2026]
eSail Sailing Simulator v.1.5.31 - eSail [2023]
Admiralty e-Navigator Planning Station v.3.4 - UKHO [2015]
MATLAB R2025b v.25.2.0.2998904 x64 (Windows) - MathWorks [2025]
DELFTship Free v.18.10 (360) - DELFTship Maritime Sofware [2026]
Kongsberg ERS MC90-V 2.6 (Dump File) - Kongsberg [20xx]
Sinking Simulator - Wicpar [2019]
Engine Room Simulator (VLCC A Simulator) - Dalian Haizhi Technology Co. Ltd. [2017]
Ship Explorer (Build 19414750) - Turbine Room Studio [2025]
The time now is: Today 00:13
