5sb1 ®   21-Dec-2023 13:43
Fishing boat designs 1. Flat bottom boats
Year: 1972
Author: Arne Frederik Haug
Genre: Technical book
Publisher: Food & Agriculture Org
Pages count: 54
Description: This publication was made in the 70's by the UN for third world countries. The boats are caravel planked (square edge planks) and they tell you to use tar or the equivalent of wildwood between the planking. They are all flat bottom utility types with no cabins or superstructure. Might be a good first build for somebody who doesn't yet have a lot of boat building skills or tools. Plywood sheathing would also work well as the designs have few complex curves. All boats are low HP outboard (20 max for the largest) designs. Would be a good place to start for a first boat, or one to leave at the cottage, hidden in the weeds at your favorite lake, or even as a decorative one hanging in then rafters of your cabin. Lots of ideas. Also has plans for two flat bottom "canoes" with transom sterns that look like oversized pirogues.
Fishing boat designs 1. Flat bottom boats_1972.pdf
Download [7 KB]
Fishing boat designs 2. V-bottom boats of planked and plywood construction - Øyvind Gulbrandsen [200...
Fishing Boats Of The World, vol. 1 - Jan Olof Traung [1975, PDF]
Fishing Boats Of The World, vol. 2 - Jan Olof Traung [1960, PDF]
Construction of 16-metre ferro-cement fishing boat - J. Fyson [1970, PDF]
Ultralight Boatbuilding - Hill T.G. [1987, PDF]
Boatbuilding: A Complete Handbook of Wooden Boat Construction - Chapelle Howard [1969, PDF]
Fishing boat construction: Building a sawn frame fishing boat - Fyson J.F. [1988, PDF]
Ultrasimple Boatbuilding - 17 Plywood Boats Anyone Can Build - Atkin C. [2008, PDF]
Boatbuilding: Cold-moulded and Strip-Planked Wood - Nicolson I. [2016, EPUB]
Boatbuilding - a complete handbook of wooden boat construction - Chapelle H.I. [1994, PDF]
The time now is: Today 11:42
