tomado, I just installed MapManager as you told me and done the steps, but it doesn't show me any kind of data when I do the search... do I need to install ucpool or something more? thanx
Jeff17, Good day, SDVJNAM027MAP25.dbv======> TZ 4 Pro =====> AEEC5A0D60FBEBAB252A SDVJNAM027MAP25.dbv======> TZ 4 Nav =====> D2E9189E0BE934812520 SDNA03TIN01.dbt is unlocked. I suggest you use Mapmanger https://seatracker.me/viewtop...hp?p=89722#89722
lionboy, SDVJEMM017MAP19.dbv >>>>5C883957740389AF19FA SDEM01TIN01.dbt >>>>>>>>> not needed pls use this excel file https://drive.google.com/uc?id=...;export=download c/p desired map /File name/ use find option in the excel file to find corresponding uc
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You can attach files in this forum You can download files in this forum
SDVJAFM210MAP22.dbv=======> 34DE3FF44BB30CDC221C
SDVJEWM226MAP25.dbv=======> D6A9F9B4A5E8B23B2567
SDVJEWM227MAP25.dbv=======> 11567BC2B12AB5E72594
The best solution is to use Mapmanager 2.6.0.0
https://href.li/?https://drive....;export=download
https://seatracker.me/viewtop...hp?p=89518#89518
Uc code for
SDVJNAM027MAP25.dbv
SDNA03TIN01.dbt
Thank you
I need UC CODES FOR
SDVJEMM017MAP19.dbv
SDEM01TIN01.dbt
FOR TIMEZERO V.4.2.0.132
Thanks .
Скиньте код для SDVJENM299SMAP25.dbv для TZ3
Пожалуйста нужны UC для
SDVJASM001MAP23.dbv
SDVJRSM002MAP23.dbv
TZ 4 pro
SDVJASM001MAP23.dbv
SDVJRSM002MAP23.dbv
TZ 4 pro
SDVJASM001MAP23.dbv
UC: 38C01E3AF14D6F0E2345
UC рабочий.
Спасибо
