John Ai ®   05-Mar-2023 13:10
Sewage Treatment Plant
Year: 2012
Author: IL Seung Co.,Ltd
Pages count: 51
Description: Sewage treatment plant ISS series treats waste water with a large amount of fixed contact media.
Model >> ISS -35N
-The way in which the waste water is oxidized and decomposed by microorganisms (bacteria) attached to fixed contact media
-Adoption of Feed-back system of solid matter and activated carbon
-Sludge production is low due to the long solids retention time
-Each tank can be divided and replaced
-Low maintenance cost and easy maintenance (Activated Carbon provides much lower maintenance cost than Membrane type.)
Sewage Treatment Plant.pdf
Download [4 KB]
Engine Room Waste Management: Oily Water and Separators - Pat Mitchell [2007, PDF]
Engine room waste mangement - Sewage and waste water treatment - Pat Mitchell [2007, PDF]
Sewage Water Treatment Plant-Technical Manual for Installation Operation & Maintenance - Facet Inter...
Quantum Reverse Osmosis RO Plant 30T Plant & 2500P UV Sterilizer Manual - QUANTUM WATER ENGINEERING ...
Waste Assessment Guidelines under the London Convention and Protocol - IMO [2014, PDF]
The Operation and Maintenance of Machinery in Motorships - N E Chell [1999, PDF]
ScanJet SC 30T Instruction Manual - www.scanjet.se [2009, PDF]
Ballast Water Treatment System Ocean Guard +Troubleshooting - Manual [2017, PDF]
Kawasaki - Eco System (K-ECOS Lite) Volume A: Operation and Maintenance: Instruction Manual - Kawasa...
ScanJet SC 15TW Instruction Manual - www.scanjet.se [2012, PDF]
The time now is: Today 20:10
