pierdolphin1950 ®   17-Nov-2021 22:23
POSOW - Oiled wildlife response
Year: 2013
Author: POSOW
Pages count: 60
Description: Some marine animals, such as marine and coastal birds, sea turtles, seals and otters are extremely sensitive to oiling. This is because these animals use the water surface (where oil floats) to rest, dive through from above to feed, or to break through from beneath to breathe. The effects of oiling may be lethal and many animals affected by the oil will die at sea. However, a certain number of oiled animals (dead or alive) may arrive at the nearest coast. Depending on the circumstances this could range from only a few animals to hundreds or thousands if the oil spill occurs in the middle of an important habitat and season. Large numbers of animals arriving ashore may cause a serious challenge to the affected country and this needs special consideration as part of the oil spill response activities.
POSOW - Oiled wildlife response .pdf
Download [6 KB]
POSOW - Oiled Shoreline Cleanup Manual - POSOW [2013, PDF]
ITOPF - Response to Marine Oil Spills Environmental impacts [2021, AVI]
API - Spills in Marshes - Planning and Response Considerations - API [2013, PDF]
Policy and Guidelines for Use of Oil Spill Dispersants (OSD) in Indian Waters - Indian Coast Guard…
Information engineering of emergency treatment for marine oil spill accidents - Lin Mu , Lizhe Wang…
Marine Mammal Welfare: Human Induced Change in the Marine Environment and its Impacts on Marine…
IPIECA - IOGP - Wildlife response preparedness - IPIECA - IOGP [2014, PDF]
POSOW - Oil Spill Waste Management Manual - POSOW [2016, PDF]
POSOW - Fishermen’s Support in OIL Spill Response - POSOW [2016, PDF]
Book of The Ocean - (Editor) Dan Peel [2022, PDF]
The time now is: Today 18:00
