veer86 ®   04-Apr-2021 22:19
ISS Detector Satellite Tracker 2.04.24 Pro Apk
Year: 2021
Version: 2.04.24 pro apk
Developer: RunaR
Platform: Android
64-bit OS compatibility: unknown
System Requirements: Android 4.1 and up
Description: Have you seen the International Space Station? It is visible with the naked eye!
If you like space or astronomy, you will like this ISS tracker app.
ISS Detector Pro includes the functionality of ISS Detector including all the Extensions and no ads.
ISS and Iridium Flares
See the ISS and Iridium flares
Radio Amateur Satellites
Track dozens of ham and weather satellites
Famous Objects
Track Hubble, X-37B, Fitsat, Tiangong and more
Comets and Planets
Track comets as they come closer to earth. Perfect for C/2011 L4 Panstarrs in March or C/2012 S1 ISON in November.
Enable ISS Detector to display the positions of the planets on the radar view.
ISS Detector Pro will tell you when and where to look for the International Space Station or Iridium flares. You get an alarm a few minutes before a pass. You will never miss a pass of the International Space Station and you will never miss the bright flashes of the iridium communication satellites. ISS Detector will also check if the weather conditions are right. A clear sky is perfect for spotting.
• Overview of the coming passes
• Weather conditions for perfect sightings
• Radar screen with path indication
• Current location on a map
• Detection of Iridium flares
• Notifications and Alarms
• Share sightings with whatsapp, twitter, gmail, email etc.
• Automatic location and timezone detection
• Widget
• Dedicated tablet layout
ISS Detector combines data from Nasa, Heavens-above.com, minorplanetcenter.net and weather from yr.no.
WHAT’S NEW
Fix for wrong magnitude in comet calculations
Updated language files
iss detector pro
Download [10 KB]
veer86 ®   04-Apr-2021 23:41
Sorry guys even after trying to seed from three devices can't see any upload, will try again tommorow.
Celestial Calculations: A Gentle Introduction to Computational Astronomy - J. L. Lawrence [2019,…
2021 Guide to the Night Sky - Storm Dunlop, Wil Tirion [2020, PDF, EPUB]
Astronomy (Merit Badge Series) - Boy Scouts of America [2010, PDF]
Compact Data for Navigation and Astronomy, 1996-2000 - B. D. Yallop & C. Y. Hohenkerk [1995, PDF]
Philip’s Astronomy Encyclopedia - Patrick Moore (Editor) [2002, PDF]
ShipAtlas v.5.0 - Maritime Optima AS [2024] [Android]
Looking for .AT5 maps for Navionics
NAVPAC 4.1 - Celestial Navigation Software from HMNAO v.4.1 - HMNAO [2020]
2025 Guide to the Night Sky Southern Hemisphere - Radmila Topalovic and Others [2024, EPUB]
Furuno Operator’s Manual Echo Sounder Model LS-4100, LS-6100 - FURUNO [2002, PDF]
The time now is: Today 20:01
