tplink24TBD ®   04-Oct-2019 21:54
Marpol Consolidated Edition 2018 (Paid)
Version: 1.0.8
Developer: Mob-Apps
Platform: Android
System Requirements: Требуется пдф-вьювер для просмотра аппендиксов марпола
Description: The advantages of MARPOL Consolidated 2018 :
• Easy to find desired regulation in few clicks
• Search inside in the chapter
• Search inside in the regulations
• Regulations are linked with each other, which improves search and save your time
• No SIGN IN required
• Quick and Fast
• Best support if required
• LICENSE – lifetime with automatic updates and upgrades.
YOU PAY FOR HIGH QUALITY PRODUCT !
NOTES:
- PDF viewer must be installed on your device to open an Appendix Certificates.
- If you have any suggestions to improve MARPOL APK let us know.
SUPPORT:
www.marineapps.co.uk
Additional info: Куплена в гугл пей
Following latest amendments are included in this application:
01 March 2018
• MARPOL Annex I - Appendix II - Form of IOPP Certificate and Supplements (MEPC.276(70))
• MARPOL Annex V - Appendix I - Criteria for the Classification of Solid Bulk Cargoes as Harmful to the Marine Environment (MEPC.277(70))
• MARPOL Annex V - Appendix II - Form of Garbage Record Book (MEPC.277(70))
• MARPOL Annex V - Regulation 10 - Placards, Garbage Management Plans and Garbage Record-Keeping (MEPC.277(70))
• MARPOL Annex V - Regulation 4 - Discharge of Garbage Outside Special Areas (MEPC.277(70))
• MARPOL Annex V - Regulation 6 - Discharge of Garbage within Special Areas (MEPC.277(70))
• MARPOL Annex VI - Appendix IX - Information to be submitted to the IMO Ship Fuel Oil Consumption Database (MEPC.278(70))
• MARPOL Annex VI - Appendix X - Form of Statement of Compliance - Fuel Oil Consumption Reporting (MEPC.278(70))
• MARPOL Annex VI - Regulation 1 - Application (MEPC.278(70))
• MARPOL Annex VI - Regulation 10 - Port State Control on Operational Requirements (MEPC.278(70))
• MARPOL Annex VI - Regulation 2 - Definitions (MEPC.278(70))
• MARPOL Annex VI - Regulation 22 - Ship Energy Efficiency
• MARPOL Annex VI - Regulation 22A - Collection and Reporting of Ship Fuel Oil Consumption Data (MEPC.278(70))
• MARPOL Annex VI - Regulation 3 - Exceptions and Exemptions (MEPC.278(70))
• MARPOL Annex VI - Regulation 5 - Surveys (MEPC.278(70))
• MARPOL Annex VI - Regulation 6 - Issue or Endorsement of Certificates and Statements of Compliance related to Fuel Oil Consumption Reporting (MEPC.278(70))
• MARPOL Annex VI - Regulation 8 - Form of Certificates and Statements of Compliance Related to Fuel Oil Consumption Reporting (MEPC.278(70))
• MARPOL Annex VI - Regulation 9 - Duration and Validity of Certificates (MEPC.278(70))
01 September 2017
• MARPOL Annex II - Appendix 1 - Guidelines for the Categorization of Noxious Liquid Substances (MEPC.270(69))
• MARPOL Annex IV - Appendix - Form of International Sewage Pollution Prevention Certificate (MEPC.274(69))
• MARPOL Annex IV - Regulation 1 - Definitions (MEPC.274(69))
• MARPOL Annex IV - Regulation 11 - Discharge of Sewage (MEPC.274(69))
• MARPOL Annex VI - Regulation 13 - Nitrogen Oxides (NOx) (MEPC.271(69))
Marpol
tplink24TBD ®   04-Oct-2019 22:02
If doesn't work, write here, I ll try to patch this apk and delete connections with Internet and Google API
Если не работает, сообщите, я пересоберу апкшник, отвяжу от гугла, и по идее всё будет чётко
tplink24TBD ®   13-Sep-2020 20:49
Guys, If after all operations as per instruction inside its not working:
I use not official, patched rom, modded kernel, and patched google play , also its FRP-free (if you have samsung)
So If you buy new phone, it can be adjusted to block such "modded apps", especially if your play protect is working
If you are Russian, пишите на почту, скину марпол.пдф в личку
macbew   27-Aug-2021 11:09
работает отлично, на последнем мультипаке.
A Really Handy Guide to Ship Certification Part 4: Keeping the Seas Clean - John Manley [2017, EPUB]
MARPOL Consolidated Edition (Readable and less size 18mb) - IMO [2017, PDF]
SEEMP Package - LR [2017, PDF]
MARPOL 73/78 Practical Guide - TOCPRO [2015, PDF]
MARPOL 73/78 Special Areas Map - Marine Lite Printing [2025, PNG]
Resolutions: MEPC.314(74); MEPC.316(74); MEPC.317(74) – MARPOL amendments - IMO MEPC [2019, PDF]
Garbage Management Plan (In accordance with MARPOL 2017, Annex V, Regulation 10(2)) - German…
POLAR Code (International Code for Ships Operating in Polar Waters) - IMO [2016, PDF]
Guide for Implementation of MARPOL Annex V - IMO [2012, PDF]
Regs4Ships - Digital Maritime Regulations - ChartCo [2019, HTML]
The time now is: Today 17:09
