Zloyalex ®   21-Nov-2018 13:19
Guidelines on Cyber Security onboard Ships v2.0
Author: BIMCO
Edition: Version 2.0
Number of pages: 51
Description: Ships are increasingly using systems that rely on digitisation, integration, and automation, which
calls for cyber risk management on board. As technology continues to develop, information
technology (IT) and operational technology (OT) onboard ships are being networked together –
and more frequently connected to the internet.
This brings the greater risk of unauthorised access or malicious attacks to ships’ systems and
networks. Risks may also occur from personnel accessing systems on board, for example by
introducing malware via removable media.
The safety, environmental and commercial consequences of not being prepared for a cyber
incident may be significant. Responding to the increased cyber threat, a group of international
shipping organisations, with support from a wide range of stakeholders (please refer to annex 4
for more details), have developed these guidelines, which are designed to assist companies
develop resilient approaches to cyber security onboard ships.
Additional info: На трекере есть предыдущее издание v1.1 2016 года. Издания отличаются. Желательно сохранить оба.
https://seatracker.me/viewtopic.php?t=18689
Table of contents
Introduction 1
1. Cyber security and safety management 2
1.1 Plans and procedures 2
1.2 Defence in depth and in breadth 4
2. Identify threats 6
3. Identify vulnerabilities 10
3.1 Ship to shore interface 11
4. Assess risk exposure 13
4.1 Risk assessment made by the company 18
4.2 Third-party risk assessments 18
4.3 Risk assessment process 19
5. Develop protection and detection measures 21
5.1 Technical protection measures 21
5.2 Procedural protection measures 25
6. Establish contingency plans 31
7. Respond to and recover from cyber security incidents 33
7.1 Effective response 33
7.2 Recovery plan 34
7.3 Investigating cyber incidents 34
7.4 Losses arising from a cyber incident 35
Annex 1. Target systems, equipment and technologies 37
Annex 2. Onboard networks 40
Annex 3. Glossary 44
Annex 4. Organisations and companies behind the guidelines 47
Guidelines-on-cyber-security-onboard-ships v 2.0.pdf
Download [4 KB]
Zloyalex ®   21-Nov-2018 13:34
Для тех кто не в курсе - согласно резолюции ИМО MSC.428(98) с 1 января 2021 года кибер-риски и кибер-риск менеджмент будет проверяться при ежегодном Аудите СУБ Компании и подтверждении ДСК (DoC).
Соответствующие изменения должны быть внесены в документацию СУБ, и будут проверяться на судах при Аудитах по ISM.
Руководство ИМО по управлению кибер-рисками можно найти в интернете MSC-FAL.1/Circ.3
7
SerTan   21-Nov-2018 13:56
47414На трекере есть предыдущее издание v1.1 2016 года. Издания отличаются. Желательно сохранить оба.
Не понятно - зачем? Новое издание от тех же разработчиков (компаний), что и предыдущее, что подразумевает замену старого новым. Поэтому как только вы сможете раздать новое (пока раздача все еще не началась) , старое издание будет перемещено в АРХИВ, где при желании, если уж оно кому понадобится, всегда его можно будет найти.
И в следующий раз перед началом раздачи выбирайте правильно язык оформления раздачи (правый верхний угол - смена флажка). Если раздаете английское издание - флаг должен быть английским, чтобы англоязычная аудитория могла прочесть описание.
Теперь же, поскольку это не было сделано изначально, исправлять русские слова в описании нужно вручную...
Так что - исправьте описание. И добавьте 3-ий скриншот (должно быть 3 минимум).
Zloyalex ®   21-Nov-2018 14:27
SerTan, Извиняюсь, я неопытный релизер - благодарю за замечания, попробую исправить.
В первом издании есть некоторые материалы, которые я не нашел в новом издании, поэтому рекомендовал оставить оба издания.
Но если поиск публикаций на трекере работает и в архиве, то это не обязательно.
Почему не прилепился третий скриншот - непонятно.
По языку раздачи - не нашел вообще где он выставляется.
Ещё раз извиняюсь - если можете, поправьте.
Zloyalex ®   21-Nov-2018 15:01
Не смог победить скриншоты - при попытке загрузить, пишет, что такой файл уже есть, но показывает в сообщении только 2 из 3 файлов. В следущей раздаче получилось так же. ((
SerTan   21-Nov-2018 15:07
Zloyalex,
Исправлено!
Для смены языка раздачи: верхний правый угол - там есть флажок с названием языка, нажимаете и выбираете из выпадающего что нужно: Русский, Английский или украинский.
The Guidelines on Cyber Security Onboard Ships - BIMCO [2018, PDF]
The Guidelines on Cyber Security onboard Ships - BIMCO [2016, PDF]
Cyber Security Workbook For On board Ship Use - Witherbys, BIMCO & ICS [2022, PDF]
Guidelines on Maritime Cyber Risk Management - Dromon Bureau of Shipping [2018, PDF]
Recommendation on Cyber Resilience [July 2020] - IACS [2020, PDF]
Guidelines on Maritime Cyber Risk Management (updated) - Dromon [2022, PDF]
Recommendation on Cyber Resilience (April 2022) - IACS [2022, PDF]
The Guidelines on Cyber Security Onboard Ships [Version 4] - BIMCO [2020, PDF]
Guidelines for Cyber Security Management System for Ships - ClassNK [2026, PDF]
Risk Focus: Cyber, Considering threats in the maritime supply chain + Q&A Cyber risks and P&I insura...
The time now is: Today 16:25
