YYa ®   15-Nov-2018 18:18
Sailboat Refinishing
Year: 1996
Author: Don Casey
Publisher: McGraw-Hill eBooks
Number of pages: 146
Description: The refinishing of the boat is one of the most important improvements and one of the most difficult tasks in the whole process of maintenance. Proper refinishing will definitely have a very dramatic impact on the appearance. Exposure to the wondrous powers of paint began for most of us with a yellow and green box of crayons. More recent experience is likely to involve rollers and walls.
Almost everyone has some painting experience. Whether your training is experienced or limited, if you select the right product and take a deliberate and careful approach to applying it to your boat, you are definitely certain to be happy with the results. This book by Don Casey is a perfect source of useful information - it clearly indicates what exactly is necessary to have on hand in order to be able to re-do a boat. For novices this book will be useful thanks to the amount of information, while for professionals it will be equally useful since it will help them bring their knowledge up-to-date with the latest developments in sailboat finishing.
By the way, it has so many common points with another popular book by same author - This Old Boat, which we also do recommend. In short, this publication contains nearly everything the boat refinisher needs to know.
Download [5 KB]
SerTan   15-Nov-2018 19:02
При оформлении английских раздач нужно переключаться на англоязычный интерфейс страницы: флажок в правом верхнем углу.
Теперь, раз это не было сделано изначально, нужно исправить заголовки в описании, чтобы англоязычная аудитория могла понять описание.
YYa ®   15-Nov-2018 21:14
SerTan,
Что мне сейчас-то сделать надо? Или уже все поправлено?
SerTan   15-Nov-2018 23:29
YYa, Чичас усЁ исправлено)))
Обычно если статус: ПРОВЕРЕНО, то все уже ОК и можно получать репутацию!
Если стоит что-либо типа: НЕДООФОРМЛЕНО, НЕОФОРМЛЕНО, ПРОВЕРЯЕТСЯ, СОМНИТЕЛЬНО - то нужно что-то менять или исправлять (при наличии рекомендаций от модератора). При этом репутация не повышается до смены статуса на ПРОВЕРЕНО.
Sailboat Refinishing (International Marine Sailboat Library) - Don Casey [1996, PDF]
Inspecting the Aging Sailboat - Casey D. [1997, PDF/EPUB]
How to Paint Your Boat - Painting, Varnishing , Antifouling - Clegg N. [2013, PDF/EPUB]
This Old Boat (Completely revised and expanded 2nd edition) - Don Casey [2009, PDF]
Sorensen’s Guide to Powerboats - Sorensen E.W. [2008, PDF]
Valve Handbook - P.Skousen [2011, PDF]
Small Craft: Piloting & Coastal Navigation - A. E. Saunders [1982, PDF]
Practical Boat Owner (December) - Katy Stickland (Editor) [2024, PDF]
Upgrading Your Small Sailboat for Cruising - Paul and Marya Butler [1988, PDF]
The time now is: Today 16:22
