samsunlusamet ®   09-Jun-2018 19:19
Hello Dear Friends,
I installed the TZ3PRO version. I did the map setup. Later the map is deleted and the screen is cracked.
What can be the problem?
How can I solve this problem.
I added screenshots. I'm glad you checked.
Attachments (11 KB)
Guest   12-Jul-2018 10:27
Harita problemini çözemedim. İnternet açıldığında haritanın crack olduğu anlaşılıyor ve sistemden düşüyor.serhat002,
fanso   08-Sep-2018 19:01
samsunlusamet, tous happen because you connect your computer to Internet
fanso   08-Sep-2018 19:02
samsunlusamet, tous happen because you connect your computer to Internet,when TZ was running
atillatkulu   03-Aug-2019 03:35
Only search on google “MaxLicV3ProR3.exe”
From results find
Torrent name is tz3pro.
I cannot give you link directly due to copyright things
eneapoma,
Guest   18-May-2020 09:47
fanso,
Hi friend same problem my system New os change problem solving
You trying to different solution
Guest   11-Jun-2020 10:49
you neet to delete files from you computer that create your TZ program all times when you connect to internet.
i have .bat file that do this, i'll try to load it soon or you can write me your mail and i'll sent it to you.
Bonmer   18-Nov-2020 16:02
Hello,
If you want TimeZero to have an access to the network , for example to get information using UDP port, you can add at the end of your hosts file this line
127.0.0.1 extranet.mytimezero.com
Hosts file is situated in the folder C:\Windows\System32\drivers\etc
And after you can remove the firewall block for Timezero, so it can access to UDP, TCP connexions to get the NMEA sentenses.
Hope it can help
Guest   16-Jan-2021 19:03
dont use internet when play maxsea sofware
mohamedskipper   22-Jan-2022 14:34
samsunlusamet, good day
didi you sold this problem ?? if yes , please describe the solution and if you have the new version of tz4 , it will be nice to send it
slts
fanso   13-Mar-2022 10:28
Hi to all.
Is any one can help me with the installing procedure about TZ v3.3?
I have the Iso of 4Gb.
Many thanks
Guest   14-Mar-2022 19:58
Please,any one can help about installing procedure of TZ V3?
Tranzas Navi-sailor ECDIS
Reeds Nautical Almanac 2022
IMO Model Course 1.22 and 7.17 of 2023 edition.
KARCO - Ten Sure Ways To Hurt Your Hands And Arms Vol 1 & 2
Mobile Crane Support Handbook 2nd ed. Edition by David Duerr
Shipping Business 2020 Foreword by HE Sultan Ahmed Bin Sulayem DP World ChairmanShipping Business…
Shipping Finance 2021 9781908833280Foreword by Dagfinn Lunde Chairman, SFG Ship Finance Global…
Harbour Fendering by Captain A. E. Robinson
looking for Ship Operations and Management 2017
Advancements in Marine Structures Proceedings of the 1st MARSTRUCT International Conference
The time now is: Today 04:26
