onlinespiderman ®   24-Jun-2018 16:08
dKart Navigator 9000 SP2 v3.41.4 build 916 + cm93 v3 WF870 + Installation tutorial for win 10 (Full Setup)
Year: 2009
Version: dKart Navigator 9000 SP2 v3.41.4 build 916
Developer: Morintech Ltd
System Requirements: Windows 10 (x86) or (x64)
Crack: Included
Description:
dKart Navigator is software for working with electronic cartography, which can be installed on a ship's computer and fully replaced with ECDIS / ECS.
Electronic chart navigation system (ECS/ECDIS) working with vector electronic charts (S-57 C-Map) that handles GPS ARPA AIS autopilot etc. sensors.
Developed in accordance with the requirements of IMO, IHO and IEC on ECDIS (Electroic Chart Display and Information System),
Navigational electronic cartographic system dKart Navigator of Morintech is designed for the following navigation tasks:
-display on the map of data on the ship's own position, course and speed based on the information of navigation devices.
-laying routes and monitoring their passage.
-mapping of ARPA and AIS (Transponder) targets on a map.
-warning the boatmaster of approaching hazards and areas with special conditions of navigation.-Automation of navigation calculations.
-automatic and manual card correction and other functions.
Additional info:
This requires a clean installation,...if you have another program that uses cm93v3 charts installed on your Pc it will probably not work!
This torrent is a result of combining the efforts of others who have previously played with dKart 9000.
Special credits go to Arcan, neosmik and oceanquakes for all their efforts and contribution to this project.
RAR PASSWORD: onlinespiderman for seatracker.me
Download [18 KB]
seal777   25-Jun-2018 11:49
Thanks and have a good day !
onlinespiderman ®   27-Jun-2018 11:03
Hello to everybody,
I see that a lot of users have downloaded this torrent.
I need confirmation that everything works fine,....the tutorial is understandable,....and that the cracks work properly.
Please confirm that everything is ok.
Best regards to all.
aungkyawmoe   27-Jun-2018 13:55
onlinespiderman, Dear sir,
well done & work properly sir .But one thing matter route import in dkart 9000 from another program rte format the program ask password.How can I solve this matter sir.
Brgd sir.
onlinespiderman ®   27-Jun-2018 14:08
aungkyawmoe,
If the route (.rte file) you are trying to import is "password protected" just enter the password.
If there is no password,...leave it blank and continue!
sakapour   08-Jul-2018 20:35
Hello (Kalispera)
I follow every step but when i start the program the charts no loaded! Also i dont received any expiration of charts!
Please advise!
Euxaristw!
herodata   10-Jul-2018 16:08
Very well organized Files. Tutorial is also good. Installed and Dkart working. But no Chart is loaded. Need Solution for that
onlinespiderman ®   10-Jul-2018 16:18
My friends sakapour, kadoka and herodata,
you need to find a serial code for your CMAP 93v3 license that has not expired.
Also, in dKart config, ,...... You need to enable the option for CMAP 93v3 charts,........ in order for the charts to display
sakapour   10-Jul-2018 21:43
Dear onlinespiderman,
Finally it worked! the only problem now is that the font size in the right menu is very big and the windows are small
Its possible to be fixed?
Thank you so much!
onlinespiderman ®   13-Jul-2018 00:44
vstarpom, the file has been downloaded 55 times and no other user had a problem!
You must be doing something wrong,....please try again!
The password is just fine.
Best regards!
karmel   13-Jul-2018 01:03
Friend Onlinespiderman, maybe it is not the means to request it, but what is the password for the files on your page? . Thank you . Greetings .
Arcan   13-Jul-2018 08:06
karmel, did you read in the first post: RAR PASSWORD: onlinespiderman for seatracker.me ???
karmel   13-Jul-2018 13:23
Yes yes, I had seen it at the beginning Arcan, thank you. I asked him for a page he has on Blogger, but maybe it does not correspond to do it here. Thanks again . Greetings .
alexalsp   14-Jul-2018 13:47
ПАРОЛЬ НА АРХИВ:
Не понимаю людей, которые паролят архивы.
cvaigon   18-Jul-2018 17:10
ЛЮДИ- СДЕЛАЙТЕ ОТДЕЛЬНУЮ РАЗДАЧУ НА КОРРЕКТУРУ-870.
А ТО НЕ СЕБЕ ,НЕ ЛЮДЯМ......................
Или я не так понял .
Так проще, что бы правообладатели не узнали...............
Furuno ECDIS Operator's Manual FEA-2107/BB/2108 - v.06.50 [2017, PDF] - Furuno
Furuno ECDIS Operator's Manual FMD-3100 - [2014, PDF]
Furuno ECDIS Operator's Manual FEA-2807/2107/2107-BB - [2005, PDF]
Transas ECDIS Demo 2.0 v.2.00.015 - Transas [2010]
Samyung ENC Chart Plotter N500/N560/NF560 Installation and Operation Manual - Samyung ENC [2009,…
ECDIS EC-8000-A/8500-A, EC-8100/8600 Operator's Manual Ed. 1.1 - Marine Systems Company TOKYO…
Synapsis ECDIS Operator Manual, Version: E02.00 or higher - Raytheon [2016, PDF]
Introduction to Digital Navigation | Including Fundamentals of Navigation - Alexander Arnfinn Olsen…
JRC ECDIS Operator's Manual JAN-2000 - [2016, PDF]
Furuno ECDIS Operator's Manual FMD-3200/3300 - Furuno [2015, PDF]
The time now is: Today 12:59
