kose ®   28-Oct-2017 18:45
Sauer Compressors Maintenance
Source: DVD-rip
Produced by: J.P. Sauer & Sohn Machinenbau GMBH
Country: Germany
Genre: Maintenance/tutorial video
Duration: ~ 00:25:00
Translation: absent
Format: MPEG-PS
Video codec: MPEG-2V
Audio codec: MPEG-1 Audio layer 2
Video: MPEG Video (PAL) (Version 2), 720x576 (4:3), 25.000 fps, 5 120 Kbps (0.494 bit/pixel)
Audio: MPEG Audio, 48 KHz, 6 ch, 224 Kbps, CBR
Index
00-Intro 00:01:51
01-Installation 00:01:54
02-Operation 00:03:54
03.1-Maintenance 3-stage-air-cooled high pressure compressors 00:02:54
03.2-Checking screwed connections 00:01:06
03.3-Oil change 00:01:23
03.4-Air filter cartridge replacement 00:00:57
03.5-Dismantling, check & assembling of new valves 00:03:08
03.6-Exchange of piston rings 00:05:51
03.7-Exchange gudgeon pin & gudgeon pin bearings 00:01:29
03.8-Checking the coupling 00:00:32
SAUER AirCompressors
Download [20 KB]
Ololo555   25-Nov-2017 22:52
Ох спасибо огромное. Очень нужные видосы! Если у вас есть ещё - залейте пожалуйста. Очень нужны обучалки по котлам, сепараторам, коих очень мало.
Maintenance & Inspection of Mitsubishi UEC-LS Diesel Engine [20XX, MPG]
Atlas Incinerators Training DVD [2005, MPEG-2]
Sauer Air Compressor - WP400 Operations Manual - J.P. Sauer & Sohn Maschinenbau GmbH [2014, PDF]
Sauer Compressor_Air Compressor_Type WP33L [2006, PDF]
Breathing Air Compressor-Onboard Ship:Maintenance [2016, FLV]
Service Framo Pump SD-200 [2005, DVD Video]
4-stage low duty compressor full manual - Cryostar [2013, PDF]
Separator HH-160 - Hutchison Hayes / Maintenance, Operation and Parts Manual [PDF]
Mitsubishi MET-SC Turbocharger Overhaul [2000, MPEG]
Instruction Manual for Tanabe Air Compressor - Model H-series - TANABE PNEUMATIC MACHINERY [2004,…
The time now is: Today 22:42
